CraigsList 7 minilites, 6.5x15 Seattle |
sixnotfour |
Jun 12 2006, 08:50 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
not mine , but I used to own em. 4Lug
http://seattle.craigslist.org/pts/170148154.html 2k with tires and lugs, six calipers also listed SOLD |
Midtowner |
Jun 12 2006, 10:20 PM
Ooooo! Group: Members Posts: 652 Joined: 21-December 04 From: Sunnyvale, CA Member No.: 3,316 Region Association: None |
Hmm, I've got four w/ lug bolts but can't decide to keep or sell. (IMG:style_emoticons/default/unsure.gif)
Attached image(s) |
Chris Pincetich |
Jun 13 2006, 12:18 AM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Hmm, I've got four w/ lug bolts but can't decide to keep or sell. (IMG:style_emoticons/default/unsure.gif) I can trade some vintage skate stickers for your 1988 Powell skateboard, some NLA XT wheelz, and possibly even a limited edition NPD off-road deck signed by the company founder and pro rider (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) |
Midtowner |
Jun 13 2006, 02:22 PM
OT: Nice to know there are fellow skaters here. I wish I didn't throw out all of my old skate gear. At today's evilbay prices, I could afford to buy a very nice /6 with what I thought was junk skate stuff. I did keep one deck though - a 1970's NOS Logan Earth Ski! (IMG:style_emoticons/default/smile.gif)
Attached image(s) |
brokenmoped |
Jun 13 2006, 04:11 PM
Member Group: Members Posts: 143 Joined: 27-May 05 From: Mission Viejo, CA Member No.: 4,152 |
Midtowner, How much you want for the minilites?
HeavyHeavy |
Jun 13 2006, 04:23 PM
Member Group: Members Posts: 62 Joined: 7-June 06 From: Albuquerque Member No.: 6,177 |
Midtowner,
I'm curious about your Minilites too. Do those have the correct offset that will allow the use of wider tires? I have some Yokohama 185/70VR-15 and they are a little too wide for the Minilite-style wheels I currently have on the car. The wheel in the front of your picture looks pretty good. What is the condition of the others? Thanks HeavyHeavy |
Midtowner |
Jun 13 2006, 05:40 PM
Thanks for the interest in the wheels. I am thinking of an option that may result in keeping the Minilites. If I do sell, it may happen in August with better pictures and more info. 185's do fit definitely. 195's too. 205's? Well, Dan (Almaden Valley) says no fit. (IMG:style_emoticons/default/smile.gif)
GaroldShaffer |
Jun 14 2006, 05:27 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Attached image(s) |
DanT |
Jun 14 2006, 05:55 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Eriks wheels are real live minilites made in England. 6.5x15.
They have an ~5.1" back spacing. with 205s and the negative camber I had in my car they would have rubbed on the inside fender well. I had rubbing issues with Fuchs and 205s on the rear...Had to go to studs and 1/2" spacers. Since everyone of these cars is different I am sure there is a car out there they would fit on... Especially if you have less negative camber and smaller tires. I think Erik should keep them for his car and sell me his Fuchs instead (IMG:style_emoticons/default/biggrin.gif) hint hint... they are very nice and would require only a small amount of clean up to be very presentable. Nice part is he has the original lug bolts and washers to mount them.... I was going to use them with spacers which introduced a whole bunch of other variables. Wish I could have made them work.... |
GaroldShaffer |
Jun 15 2006, 06:25 AM
So are mine. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/thumb3d.gif)
For those that want Minilites go HERE Attached image(s) |
HeavyHeavy |
Jun 19 2006, 02:27 PM
Thanks for the info about the offset and tire size. That'll
help me a lot. I'm hoping to have new wheels before August, but I'd still be interested if yours are for sale then. |
DanT |
Jun 19 2006, 05:32 PM
So are mine. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/thumb3d.gif) For those that want Minilites go HERE Wasn't implying yours weren't real. (IMG:style_emoticons/default/smile.gif) But theone Erik has are 6.5" wide vs, 6". Also from your picture...my car is about 1.5 inches lower and has 2.75degrees of negative camber in the rear. Makes the inside clearance an issue...at least on my car. That is why I had to go to studs and spacers to avoid tire rub on the inside. couldn't come up with a combination that would work with the mounting surface that was on the minilites. (clear shank for centering wheel and then flat washer with flat faced lug bolt) I have a good friend that is a machinist and he says the old minilites...which Erik's are (like 30yrs old), are a very pourous casting and do not amend themselves to machining at the mounting area. The only way to make them work with studs and spacers is to make a shim that screws onto the studs to center the wheel and then use a machined flat lug nut along with the standard mounting washers. He was going to do all of this for me but I decided to stay with the Fuchs for now and go another direction in the future. (IMG:style_emoticons/default/smile.gif) |
JPB |
Jun 19 2006, 05:54 PM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
All that is min i: minskirts, minibras, minilights. My man parts say they are #1!
(IMG:style_emoticons/default/chowtime.gif) How you say,"mini seafood buffet?" |
Midtowner |
Jun 19 2006, 06:40 PM
All that is min i: minskirts, minibras, minilights. My man parts say they are #1! (IMG:style_emoticons/default/chowtime.gif) How you say,"mini seafood buffet?" (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 05:30 PM |
