Bilstein Strut Housing question |
Qarl |
Sep 30 2003, 11:26 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Do All Bilstein Strut housings have the upper cover like the picture below?
Attached image(s) |
Qarl |
Sep 30 2003, 11:27 PM
My suspension didn't come with them. Are they missing? If so, does anyone know where to get a set ASAP?
Attached image(s) |
Brad Roberts |
Sep 30 2003, 11:56 PM
Any of them will work (including your stock 914 shock covers.. they just wont be green)
B |
Korijo |
Oct 1 2003, 01:56 AM
[]D o [] o []V[] o []D Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
I got my set, Karl. ALREADY blasted...
Want 'em ?? |
914werke |
Oct 1 2003, 02:16 AM
"I got blisters on me fingers" Group: Members Posts: 10,120 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Karl did those come stock on your /6?
Supposedly some /4's also came so equiped but after owning 6 or 7 cars including an Creamsicle Ive never seen anything other than the (Black) Boge strut housing OE equiped? (IMG:style_emoticons/default/unsure.gif) |
maf914 |
Oct 1 2003, 06:33 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
If I recall correctly from his previous posts, Karl's car has 911 struts.
My 76 has black struts, I assume originally with Boge inserts. Mike |
Qarl |
Oct 1 2003, 08:32 AM
Okay... next question... do they just slide on over the shaft and are held in place by the washers and nuts that attach it to the camber plate or is there an additional nut on top or some way of securing it to the strut insert?
Thanks! |
-P- |
Oct 1 2003, 09:34 AM
P-Factor Group: Members Posts: 207 Joined: 1-July 03 From: Dallas, TX Member No.: 873 |
The hole on the stock covers is too small for the bilsteins. They are held in place, at least on mine by a rubber grommet/washer on the strut shaft and sandwiched between the camber plate up top.
maf914 |
Oct 1 2003, 09:35 AM
The Haynes manual shows the shock body, the rubber spring or stop, the upper cover, all up against the bottom of the camber plate, without additional washers or nuts. Washer and nut then thread on above the plate.
You might want to check the 914 PET CD for another view. Mike |
-P- |
Oct 1 2003, 09:37 AM
QUOTE(maf914 @ Oct 1 2003, 09:35 AM) The Haynes manual shows the shock body, the rubber spring or stop, the upper cover, all up against the bottom of the camber plate, without additional washers or nuts. Washer and nut then thread on above the plate. You might want to check the 914 PET CD for another view. Mike Yeah, that is more or less what I meant to say. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 07:34 AM |
