are early /4 calipers same as /6? |
Aaron Cox |
Oct 1 2003, 06:36 PM
was wondering because the early /4 use the same pads as a /6. the later /4's have their own pads.
/6 pads are bigger right? |
mskala |
Oct 1 2003, 08:12 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
The /6 REAR pads are bigger than the /4 rear pads. In fact
most of the time I see errors from many parts places that list the same rears for both. The /6 rear is the same as the early (pre 73) /4 front pad. |
mskala |
Oct 1 2003, 08:16 PM
... And you have to drill one of the pad holes bigger to fit the pin.
Maybe I missed your real question: The /6 front calipers are different from the /4, the pads may be the same size, but the pistons are a lot bigger (in the same ratio of 19mm/17mm master cylinder, BTW). The later /4 pads were thicker, not bigger. |
Aaron Cox |
Oct 1 2003, 08:24 PM
thanks for clearing that up- one can buy new 914/6 rear calipers for ~ 400 apiece (IMG:style_emoticons/default/wink.gif)
oops! thats for front calipers- sorry ! (IMG:style_emoticons/default/sad.gif) This post has been edited by acox914: Oct 2 2003, 08:43 PM |
ArtechnikA |
Oct 1 2003, 09:00 PM
QUOTE(acox914 @ Oct 1 2003, 06:24 PM) ... one can buy new 914/6 rear calipers for ~ 400 apiece (IMG:style_emoticons/default/wink.gif) really ? do tell where, please ... BTW - it doesn't affect the pads, but the /6 front caliper is also wider to accommodate the vented disk... |
Lo-Fi Version | Time is now: 17th June 2024 - 03:40 AM |
