was wondering because the early /4 use the same pads as a /6. the later /4's have their own pads.
/6 pads are bigger right?
mskala
Oct 1 2003, 08:12 PM
The /6 REAR pads are bigger than the /4 rear pads. In fact most of the time I see errors from many parts places that list the same rears for both. The /6 rear is the same as the early (pre 73) /4 front pad.
mskala
Oct 1 2003, 08:16 PM
... And you have to drill one of the pad holes bigger to fit the pin.
Maybe I missed your real question: The /6 front calipers are different from the /4, the pads may be the same size, but the pistons are a lot bigger (in the same ratio of 19mm/17mm master cylinder, BTW). The later /4 pads were thicker, not bigger.
Aaron Cox
Oct 1 2003, 08:24 PM
thanks for clearing that up- one can buy new 914/6 rear calipers for ~ 400 apiece
oops! thats for front calipers- sorry !
ArtechnikA
Oct 1 2003, 09:00 PM
QUOTE(acox914 @ Oct 1 2003, 06:24 PM)
... one can buy new 914/6 rear calipers for ~ 400 apiece
really ? do tell where, please ...
BTW - it doesn't affect the pads, but the /6 front caliper is also wider to accommodate the vented disk...
