Help Help Help, Infernal Brake System (electrical) |
aveale |
Jun 18 2006, 09:11 AM
Fun Times Group: Members Posts: 194 Joined: 18-August 04 From: Ottawa, Canada Member No.: 2,563 |
family,
this determines whether or not the car goes back to the shop. what else makes the red emergency brake light flash??? i know the "tick-tick" when the brakes have been bled/no pressure i know my emerg brake switch works (checked with volt meter a couple of times) just started to happen last nite... relay switch???? help?!?!?!? T (IMG:style_emoticons/default/sad.gif) |
Allan |
Jun 18 2006, 09:58 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Maybe a bad m/c or m/c switch?
Dave_Darling |
Jun 19 2006, 12:45 PM
What makes it go "tick" is two intentional things, and a few more unintentional ones.
First, the handbrake handle has a button under it. If the handle is up, the tab on the bottom will not press the button, which grounds a wire and turns on the tick-tick-tick. Sometimes the handle is tweaked just enough for the tab to miss the button, so that is worth checking as well. Second, the master cylinder has a "warning switch" in it which gets turned on any time part of the brake system loses pressure. The most common pressure loss is when the brakes are bled. Most switches need to be manually re-set; find the switch (the thing that has one or two wires plugged into it on the master cylinder, found in the steering rack compartment under the car). Feel for a rubber nipple on the switch. Press it in toward the MC; there is a button under that nipple that you are pressing. That should reset the switch. The unintentional things usually have to do with the brown/white (brown/yellow??) wire to the handbrake handle button or to the MC switch getting shorted to ground somehow. Like falling off and touching the chassis, or getting plugged in wrong, or wearing through the insulation and shorting to ground that way. Good luck! --DD |
aveale |
Jun 20 2006, 01:46 PM
Thanx guys,
It was a stupid question as it was the MC switch (which i have visited before). For watever reason the brake light was flashing in addition to the tick tick tick (never the light before?!?!?) letting me know that the switch needed to be reset. Cheers, T |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:34 AM |
