Lug bolt covers from VW, What year or size is compatible? |
BigDBass |
Jun 20 2006, 08:44 AM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
Hi, I've read that the black plastic lug bolt covers for VW bugs will work for 914s. What years/models VW covers will fit? Or what size? Most of the ones I've found are 19mm, but my lug bolts (for Mahles) are 38mm. |
SLITS |
Jun 20 2006, 09:20 AM
Don't remember, but I think they are 17 mm. Stock lug bolts for steel wheels on a 914 and later model bugs.
I could go measure one, but..................... |
TROJANMAN |
Jun 20 2006, 10:13 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
stock lug head size on a 914 are 19mm (fuch, mahle, steel)
most vdubs are 17mm i have vdub bolts in my 914 that are 17mm (IMG:style_emoticons/default/smile.gif) the 38mm you refer to on your mahles should be the length, not the head size (IMG:style_emoticons/default/wink.gif) |
BigDBass |
Jun 20 2006, 09:40 PM
Thanks.
I tracked down some universal 19mm black lug caps so let's hope they work out. Much cheaper compared to $3 each from performanceproducts. |
hmeeder |
Jun 20 2006, 11:20 PM
Dante's Sportscar Group: Members Posts: 352 Joined: 21-November 04 From: San Diego, CA Member No.: 3,154 |
I think the covers from the '75-ish superbeetle fit.
BigDBass |
Jul 14 2006, 10:28 AM
I tried "19MM Universal Black Lug Caps" (C16-111-1005-BK) and while they fit onto the lugs, they don't seat fully. I'll keep looking.
BigDBass |
Jul 14 2006, 10:32 AM
Next I shall try "LUG NUT CAPS, SPORT, BUG 75-79" (IMG:style_emoticons/default/biggrin.gif)
JeffBowlsby |
Jul 14 2006, 01:43 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Stoddards has them inexpensively if you buy a whole set.
Cap'n Krusty |
Jul 14 2006, 01:55 PM
stock lug head size on a 914 are 19mm (fuch, mahle, steel) most vdubs are 17mm i have vdub bolts in my 914 that are 17mm (IMG:style_emoticons/default/smile.gif) the 38mm you refer to on your mahles should be the length, not the head size (IMG:style_emoticons/default/wink.gif) All air cooled VWs had 19mm wrench size lug bolt heads, and all Vanagons did, too. Most water cooled VWs use the 17mm wrench size. The Cap'n |
Lo-Fi Version | Time is now: 6th June 2024 - 03:44 PM |
