nycchef |
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None ![]() |
have to move my pump 73 1.7, have read the articles on pelican and aa but still not clear to me. not a budding mechanic after all. anyone have pics of the installion. pics would probably help me a lot, cartoons even more
toon1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 ![]() |
did it to my 73, 1.7. It's not that hard. I moved it under the fuel tank like a 74. I used the stock mounts, rerouted the wires ( PITA). Also the fuel filter needs to be relocated. I put mine under the tank, I cut off the stock filter mount and welded it to the wall under the fule tank on the pass side. It turned out slick, I could change the filter through the acess hole under the car. I didnt have the means to take pics at the time, I took a couple of pics of the nuts that are holding the pump mount. Hope this helps a little
Attached image(s) ![]() ![]() |
wilchek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 ![]() |
not a big deal. Pump has a line going to the injectors and then a return line after the the injectors take the fuel they need the left over is cycled back so just need one line for supply and one for return. I have mine mounted to the cover under the tierods, but it would be better to mount in front trunk like 75and76 models were done. Make sure u put the filter in a good spot and get a good one that is desigend for a high pressure FI system.
nycchef |
thanks guys , a little clearer now. one question where did you run the new lines?
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
Front trunk....stock pump and new filter
Attached image(s) ![]() |
Lo-Fi Version | Time is now: 19th July 2025 - 03:25 AM |
