> Make up your mind., No fuel, or too much.
BMXerror
post Jun 24 2006, 01:18 AM
Well, I got the new fuel pump today, put it in, and it certainly makes pressure. The thing runs way too rich now. It won't even idle without flooding out and dying. I already suspected this, and long story short after all the diagnosis, I'm damn near positive that it's got a couple stuck injectiors. I'm not sure which ones or how many, but cylinder 2 and the enrichment injector are suspect. Anyhoo, my question is this: is it posible to remove and clean the injectors to unstick them, or is it one of those "throw 'em away and get new ones" things? For the price of a set of NEW injectors, I could get a set of weber carbs....... if only I could afford those. Anyways, I only ask because I've worked both of my cars all day and am too lazy to get up and read the manual. Thanks.
Mark D.
Replies(1 - 1)
Dave_Darling
post Jun 24 2006, 09:46 AM
914 Idiot
There is no "enrichment injector" on a stock system. There's the cold-start valve, but that should only be active in cold weather while the starter is cranking. You can clamp the fuel line shut if you're worried about that (if it's a reasonably new line!) or pull the CSV from the manifold and watch to see if it is leaking at all.
Check the injectors. Stick 'em in a couple of jars and crank the starter. If they're stuck, it should be pretty obvious...
--DD
- Lo-Fi Version Time is now: 15th April 2026 - 01:23 AM
