Friday, 15 August 2025
> is there a quick easy way to find out what size tortion bars, i have up front???
Dr. Roger
post Jun 25 2006, 10:25 PM
A bat out of hell.
i got the front suspension from a 914 GT/6 conversion and i'm thinking these tortion bars are upgraded because they are so dang stiff....
can they be simple popped out and measured?
how? what's stock in a 911?
oh sorry, 5 bolt 911 suspension......
thanks all,
roger
Replies(1 - 9)
Aaron Cox
post Jun 25 2006, 10:41 PM
Professional Lawn Dart
stock in a 911 was 19mm....
pull front valence off
pop off rear ride heait adjuster
piece of wood and a hammer.. and beat it out the front (it should push the dust cap out no prob)
push it out enough to get a set of calipers on it to measure..... and report back (IMG:style_emoticons/default/smile.gif)
AA
Dr. Roger
post Jun 25 2006, 10:57 PM
A bat out of hell.
aaron,
i removed the height adjuster and it slid out the back.
23.4....
it's white in color. ???
any idea who makes it?
DanT
post Jun 25 2006, 11:03 PM
Going back to the Dark Side!
sway away? (IMG:style_emoticons/default/smile.gif)
Dr. Roger
post Jun 25 2006, 11:05 PM
A bat out of hell.
pic.....
23.4 mm's.
Dr. Roger
post Jun 25 2006, 11:09 PM
A bat out of hell.
dan, sure enough....
they look like sway away power barz... 23mm. =-)
PP is asking $230 a set. =-)
i think i need to downgrade to some 19's or 21's.
thanks again!! =-)
Aaron Cox
post Jun 25 2006, 11:13 PM
i have 22mm sway aways... and yep, they be white...
23mm bars mean huge springs in da back....
21's are nice.
DanT
post Jun 25 2006, 11:17 PM
My vote is for 21s for a car that will see track/AX duty. Balanced with at least 180# rear springs. If you go bigger than that in the front you need 225# rears or more.
If you don't upgrade the rear springs the car will push alot.
Otherwise 19s are a good compromise between ride and handling. IMHO (IMG:style_emoticons/default/smile.gif)
McMark
post Jun 26 2006, 01:27 AM
914 Freak!
Bigger springs and roller bearings. (IMG:style_emoticons/default/laugh.gif)
Dr. Roger
A bat out of hell.
i appreciate all of your opinions.
is there anyone who wants to step up their torsion bars from 911 21mm to 23mm?
let's swap! =-)
- Lo-Fi Version Time is now: 14th August 2025 - 09:15 PM
