Sheared exhaust bolt: Is this bad? |
krazykonrad |
Jun 26 2006, 03:26 PM
Senior Member Group: Members Posts: 1,127 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
I noticed that one of my exhaust bolts sheared off. Its the last one back on the passenger's side. It probably explains the rattling that I couldnt trace. Anyway, is this a serious problem? ANy clues to why this happened? Does this have anything to do with the oil leak in the picture?
Many thanks! Konrad 72/4 Attached image(s) |
Brad Roberts |
Jun 26 2006, 03:29 PM
Is it sheared off or did it just fall out.
Typically they dont shear off unless somebody is trying to break them loose. B |
Allan |
Jun 26 2006, 03:30 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
It's bad because you'll have an exhaust leak. It can be repaired by either using an easy-out or drilled and heli-coiled.
It isn't what the oil leak is from... |
TROJANMAN |
Jun 26 2006, 03:35 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
gint just fixed one of these. i am sure he will tell us how much fun it was. (IMG:style_emoticons/default/smile.gif)
krazykonrad |
Jun 26 2006, 07:54 PM
I definetly wasnt twisted out by me. It just fell out one day. It may have been sheared before or it may somehow have sheared while it was in and then the end fell out I dont know. ????????
Anyway here's a picture of the bolt. THanks again! Konrad Attached image(s) |
Mueller |
Jun 26 2006, 07:59 PM
there is no relationship between that and the oil...if left as is, you have a good chance of an exhaust leak that'll end up melting/burning the sealing surface and you'll be searching for a new cylinder head...
krazykonrad |
Jun 26 2006, 08:02 PM
Sorry wrong pic!
Attached image(s) |
Mueller |
Jun 26 2006, 08:06 PM
that is broken...you are hosed (IMG:style_emoticons/default/blink.gif)
you might get lucky and have enough of the stud sticking out to grab, but it'll be tough...if attempted to drill out a broken stud twice, 1st time worked well...second time I screwed the pooch and the motor had to be dropped so that I could remove the head... |
Hammy |
Jun 26 2006, 08:17 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
I never got this. (IMG:style_emoticons/default/wacko.gif)
Can a stud just be JB welded back in and end of story? |
ptravnic |
Jun 26 2006, 08:36 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
I second trying an ez-out. Go slow and it will work. I did this a couple years ago. Took a couple hours and a lot of patience but got another bolt up and in there and have no leaks since!
-pt |
nebreitling |
Jun 26 2006, 08:57 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
yikes. how do you have it if it just fell out?
whatever you do, it's a major pita. get the car up high on jack stands, drop the exhaust (you'll probably strip/pull another couple studs in the process...), try an EZ out, reinstall new stud with some JB-Weld on the threads, rehang the exhaust with fresh copper gaskets and nuts. worst case scenario is having to pull that head. please do wear safety goggles, as little bits of metal rust and oil coming into your eye can be a not-fun trip to the ER. drinking heavily does not make this job go more easily. |
Mueller |
Jun 26 2006, 11:43 PM
I never got this. (IMG:style_emoticons/default/wacko.gif) Can a stud just be JB welded back in and end of story? I seriously doubt it would work in that application....I guess you could try and get back to us (IMG:style_emoticons/default/smile.gif) |
So.Cal.914 |
Jun 26 2006, 11:57 PM
Same one broke on mine, I think it was stress fracture. EZ out will work just take
your time don't try to back it out to fast. . When you drill out the stud use spray cutting oil and do, as mentioned before wear safty glasses there will be rust, metal shavings, oil and various other UFO's (unidentified falling objects). Any questions PM me. |
krazykonrad |
Jun 27 2006, 12:13 PM
THanks for all the help! I think I'm going to let my local shop do the out drilling as I really dont want to f-up the head myself. More importantly I dont want to tell the Mrs. that I f-up up the head my self and I need to buy a new one.
Thanks again, Konrad (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:06 PM |
