what axles to use with a 915? |
SirAndy |
Jun 26 2006, 03:32 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
so, i'm going to buy a 915 that is already flipped for a 914 ...
now the question is, what to run for axles? i got's real 5-lug hubs etc. from what i believe is a early 911. they fit the 914 wheel bearing ... (IMG:style_emoticons/default/smile.gif) Andy |
McMark |
Jun 26 2006, 03:33 PM
Brad Roberts |
Jun 26 2006, 04:08 PM
It depends on what output flanges you have on the tranny (or if it has a fine spline or course spline LSD in it)
If it has a course spline LSD or course spline open diff.. you can use the 930 style early 911 complete axle assemblies with early 911 5 lug drive flanges out in the control arm. B |
echocanyons |
Jun 26 2006, 04:15 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
The setup Brad mentioned is what I am using.
The only problem with it is the axels have recently become really hard to locate or really expensive when you can find them. I picked up a set from Jason at paragon for the "old" pricing just a week or so ago. |
SirAndy |
Jun 26 2006, 04:26 PM
It depends on what output flanges you have on the tranny (or if it has a fine spline or course spline LSD in it) If it has a course spline LSD or course spline open diff.. you can use the 930 style early 911 complete axle assemblies with early 911 5 lug drive flanges out in the control arm. wait, wouldn't those fit my 944 CV's and axles? because i had to get a set of late '70 911 output flanges for those to make them work with the 901 ... is the 915 wider than the 901? meaning, does my distance from the trailingarm to the output flange change? axles need to be longer/shorter/same ??? (IMG:style_emoticons/default/idea.gif) Andy |
Brad Roberts |
Jun 26 2006, 04:55 PM
901/915/930/G50 all have the same side to side distance between the flanges.
The early 911 axles are shorter than the 914 axles by .500 several people sell spacers for this.. but I have never ran them. The CV's have more then .750 in play. This means only .250 split between the two. You have seen them ran for several years now in a 914 with 355hp and 8K RPM (ha ha and person who doesnt really know how to "blip" throttle downshift). If you are running early 911 drive flanges in the control arm... then the early 911 4 bolt 2 pin stub axles slide in right now. They just barely clear the control arm. B |
wbergtho |
Jun 26 2006, 05:06 PM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
I am running early 911 half shafts & CVs. I had a set of custom spacers machined (I believe they are 1" wide). It was my impression that you have to run spacers when running a 915 or 930 gearbox in a 914. If indeed you don't need them, I spent a bunch of money for no reason on spacers. Perhaps I'm wrong, but I thought you needed them. All the better if you don't. You won't have as many problems with CV bolts loosening and CVs leaking grease w/out them. Incidently, I have since learned that if you want/need spacers...you can take apart a pair of old useless CVs and use the hub as a spacer. Randy Beck taught me that trick.
SirAndy |
Jun 26 2006, 05:11 PM
901/915/930/G50 all have the same side to side distance between the flanges. The early 911 axles are shorter than the 914 axles by .500 several people sell spacers for this.. but I have never ran them. The CV's have more then .750 in play. This means only .250 split between the two. You have seen them ran for several years now in a 914 with 355hp and 8K RPM (ha ha and person who doesnt really know how to "blip" throttle downshift). If you are running early 911 drive flanges in the control arm... then the early 911 4 bolt 2 pin stub axles slide in right now. They just barely clear the control arm. ok, let me re-phrase my question ... i already got, outside to tranny: 911 hub that fits the 914 wheel bearing, 944 stub axle that fits the hub, 944 CV, modified 914 axle to fit the 944 CVs, 944 CV, 911(915) output flange to fit the 901 all of this fit's perfectly using the 901, correct length (because i'm using the 914 axle shaft), bigger CV's (944) etc. now my question is: if the 914 has the same overall width from output flange to output flange, my whole axle should just bolt right up to the 915, as my setup is supposed to use 915 output flanges anyways ... correct ???? (IMG:style_emoticons/default/idea.gif) Andy |
Brad Roberts |
I only know of one company who tells everyone they need them (they happen to sell them)
People are scared of CV's. I'm not. Wait until you start seeing more pics of a Boxster engine and tranny. The axles have a HUGE angle on them and the CV's are close to the 911SC sizing. The Bus axles are really short. They require a good sized spacer. B |
Brad Roberts |
Jun 26 2006, 05:14 PM
Correct a mundo.
IF..IF the 915 has course splined open or LSD. Some of the 915's have a fine splined output flange. In this case you tranny ouput flanges would not work. I wish I had a picture to show you. B |
SirAndy |
indeed you don't need them, I spent a bunch of money for no reason on spacers. no, you didn't waste any money. the 911 axles are shorter than the 914 axles. the car brad is talking about has about 1" of suspension travel and something like 500lbs springs ... on a more stockish 914, the stock 911 axles will be too short if you load/unload the suspension ... (IMG:style_emoticons/default/wink.gif) Andy |
SirAndy |
Jun 26 2006, 05:16 PM
Some of the 915's have a fine splined output flange. In this case you tranny ouput flanges would not work. so, the difference between coarse and fine is not only on the inside of the tranny but also the boltpattern/size on the outside where the CV mounts? meaning, the two setups use different CV sizes? (IMG:style_emoticons/default/idea.gif) Andy |
Brad Roberts |
Jun 26 2006, 05:18 PM
True, it doesnt have the same suspension travel...but...
still a non-issue with the amount of angle still left in them remember: these are the same size as a 930Turbo CV joint. The ones used in Baja 1000 Off road racing for 20+ years in cars with 30inches of suspension travel. Stretching one versus angle is a little different |
Brad Roberts |
Jun 26 2006, 05:21 PM
Correct.
The ideal situation for you: course splined diff so your 914 output flanges would slide right in. If the diff is fine splined... your options are VERY limited. You would be limited to the 911SC output flange. I honestly beleive there are more course splined diffs out there than fine splined. When you order a Guard ZF style clutch plate LSD: he asks you: course or fine? |
SirAndy |
Jun 26 2006, 05:39 PM
The ideal situation for you: course splined diff so your 914 output flanges would slide right in. ok, just to be clear on this, my 944 setup uses 911 output flanges, *not* 914 output flanges ... i have a set of coarse spline 911 output flanges that i was going to drop into the 901 ... just to be clear (IMG:style_emoticons/default/biggrin.gif) the only 914 part in my axle assembly is the actual axle shaft, everything else is either 911 or 944. including the output flanges. which are from a 911, not a 914. no LSD in the box, that would have been too good of a deal ... (IMG:style_emoticons/default/rolleyes.gif) Andy |
Brad Roberts |
Jun 26 2006, 05:42 PM
That is ok on the 911 tranny flanges.
If they slide into the 901.. they will slide into the 915 with course spline. FYI: a 901 LSD can be used in a 915. A 915 LSD can be used in a 930 box. A G50 LSD can be used in a 996/997 tranny or a BoxsterS box. B |
SirAndy |
Jun 26 2006, 05:57 PM
That is ok on the 911 tranny flanges. If they slide into the 901.. they will slide into the 915 with course spline. good, now that we got that out of the way, one last question ... don't most 915s use the 100mm size CVs ??? if so, it doesn't matter if it's coarse or fine spline as long as the output flange fit's my 100mm 944 CVs ... correct? (IMG:style_emoticons/default/idea.gif) Andy PS: to refresh your memory ... Rear 5-Lug with 944 Parts, PART II http://www.914world.com/bbs2/index.php?show...170&hl=944+axle Rear 5-Lug with 944 Parts, PART III http://www.914world.com/bbs2/index.php?show...218&hl=944+axle |
JFJ914 |
Jun 27 2006, 06:41 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
[good, now that we got that out of the way, one last question ...
don't most 915s use the 100mm size CVs ??? Yes if so, it doesn't matter if it's coarse or fine spline as long as the output flange fit's my 100mm 944 CVs ... Yes correct? (IMG:style_emoticons/default/idea.gif) Andy |
PRS914-6 |
Jun 27 2006, 08:47 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
That is ok on the 911 tranny flanges. If they slide into the 901.. they will slide into the 915 with course spline. FYI: a 901 LSD can be used in a 915. A 915 LSD can be used in a 930 box. A G50 LSD can be used in a 996/997 tranny or a BoxsterS box. B One thing that should be noted.......The 915 non LSD carrier has a different bore size than than a 901 where it slides in the carrier but the splines look identical. The flanges slide right in a 915 and first impression is OK and they feel OK until you measure them. They look and feel like they will work but it won't. The bore size is significantly different. I do not know about the 944's. If you need the measurement, I can provide them I am using 108mm output flanges from a 69 911S (901) that fit perfect on both ends of the rear drive. Also using Sway-A-Way axles. The weak point will be the tranny |
SirAndy |
Jun 27 2006, 09:03 PM
I am using 108mm output flanges from a 69 911S (901) that fit perfect on both ends of the rear drive. Also using Sway-A-Way axles. The weak point will be the tranny hey paul, how is your car coming? (IMG:style_emoticons/default/bye1.gif) i'm hoping i can use whatever is on the 915 right now. as long as the current output flanges are for 100mm CV's, i'm all set ... we shall see when i take posession of the tranny ... (IMG:style_emoticons/default/smile.gif) Andy |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:59 PM |
