Setting rocker geometry |
michaelmoo |
Jun 29 2006, 10:29 AM
Member Group: Members Posts: 312 Joined: 21-May 04 From: Kennesaw, GA Member No.: 2,092 |
I read the article in Hot VW that is about the RAT 2270 build up. It talks a lot abot rocker geometry and I was wondering more about it. I know it is important and understand why you want to do it but was wondering if there is a good article or info on actually doing it. I found the following info:
http://www.superbeetles.com/performance101/aug.htm Any comments? Additions? Corrections? Thanks, Mike |
yeahmag |
Jun 29 2006, 11:16 AM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
That about does it. Expect it to take a VERY long time the first time you do it. Lots of beer and calming thoughts... You can do it.
-Aaron |
URY914 |
Jun 29 2006, 11:22 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,967 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
That looks like a good write up. When I was stting my pushrod length it was alot of slow work and hard to discribe to someone unless they do it. I was on the phone witrh Jake half-dozen times before I really got it. I never found a good step by step proceedure. Maybe that's it.
Paul |
michaelmoo |
Jun 29 2006, 11:29 AM
Thanks for the replies. I am planing on getting a 2270 kit from him and was just doing my homework. I've rebuilt engines before, but they were just stock rebuilds. I know Jake was writting a set of manuals a time ago, but that got put on the back burner. Maybe he will now becasue of the Hot VW exposure.
scotty b |
Jun 30 2006, 04:55 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
(IMG:style_emoticons/default/sad.gif) Unfortunately for us it seems Jake may have left. After his last posting he took the usual B.S. from some tire kicking whiners that can't afford his product, deleted the whole thread and hasn't been back. I can't say that I blame him either. He has put up with a lot more crap than I would have! I'm sure though that he still supports our community and is more than willing to help those who appreciate what he does and don't mind paying for good quality products.
Brad Roberts |
Jun 30 2006, 05:04 PM
He is in the "wings" monitoring from above.
All of us take a certain amount of shit from people and need a break from time to time. This is Jakes "brake". We will see what happens next! B |
Aaron Cox |
there are 3 variables...
aduster depth, pushrod length, rocker shims took a few hours with help of joe sharp to get mine done.... |
scotty b |
Jun 30 2006, 06:01 PM
He is in the "wings" monitoring from above. All of us take a certain amount of shit from people and need a break from time to time. This is Jakes "brake". We will see what happens next! B |
DNHunt |
Jun 30 2006, 06:46 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Aaron
Those are the variables The goal is maximun attainable lift with the conditions that the adjuster parallel with valve stem at half lift and enough threads so you can adjust lash. Easy enough but strictly trial and error and therefore time consuming. Damn hard thing to explain but easier to see Dave |
Aaron Cox |
Jun 30 2006, 07:05 PM
Aaron Those are the variables The goal is maximun attainable lift with the conditions that the adjuster parallel with valve stem at half lift and enough threads so you can adjust lash. Easy enough but strictly trial and error and therefore time consuming. Damn hard thing to explain but easier to see Dave werd... at half lift you want the valve adjuster parrallel to the valve stem.... mark when it opens, when it closes, divide that radial distance by two, then you just shim and play with the pushrod tool until you get it right (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 11:59 PM |
