Transmission weight, 915 / G50 / Tiptronic |
Randal |
Jun 30 2006, 03:48 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Anyone have the weight on these babies? |
Brad Roberts |
Jun 30 2006, 03:54 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
You alive?
I can weigh them sometime over the holiday. The 915 weighs 120lbs about 15lbs more than a 901 I have a G50 and a Tip I can weigh at the shop. B |
Aaron Cox |
Jun 30 2006, 03:59 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
brad, we weighed a 901 at joe sharps.. 75 exact without starter....
Dave_Darling |
Jun 30 2006, 04:01 PM
Approximate weights, from a Pano article a number of years back:
901- 75 lbs 915 - 125 lbs G50 - 175 lbs No data on the Tip; never been interested enough for any info I've read to stick. --DD |
Randal |
Jun 30 2006, 04:39 PM
Brad Roberts |
Jun 30 2006, 04:44 PM
With or without gear lube Aaron?
I'll sling the TIP up on a scale tonight and post back or call you. B |
Aaron Cox |
Jun 30 2006, 04:46 PM
IIRC with....
Brad Roberts |
Jun 30 2006, 04:47 PM
Randal is getting old. He is trying to figure out if he can put a "Chicktronic" in his 914.. (IMG:style_emoticons/default/alfred.gif)
I miss you Randal (IMG:style_emoticons/default/beerchug.gif) B |
Aaron Cox |
Jun 30 2006, 04:48 PM
"sliptronic" (IMG:style_emoticons/default/tongue.gif)
nebreitling |
Jun 30 2006, 04:54 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
WTF are you doing now, Randal?!
wbergtho |
Jun 30 2006, 08:14 PM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
What does my 930 trans weigh? I'm guessing about 135-140 lbs
Randal |
Jun 30 2006, 09:22 PM
Attached thumbnail(s) |
Randal |
Jun 30 2006, 09:25 PM
And detail.
McMark |
Jun 30 2006, 10:04 PM
Somebody put bubble gum in your engine. (IMG:style_emoticons/default/ohmy.gif)
Looks like it might get closed up soon. (IMG:style_emoticons/default/Jumpy.gif) |
Randal |
Jul 1 2006, 09:06 AM
Somebody put bubble gum in your engine. (IMG:style_emoticons/default/ohmy.gif) Looks like it might get closed up soon. (IMG:style_emoticons/default/Jumpy.gif) Yea, should be this weekend. |
Aaron Cox |
Jul 1 2006, 11:52 AM
NICE crank!!!
80mm? 78? looks killer randal! no straight cut camgears? wassup with that LOL |
Randal |
Jul 1 2006, 01:58 PM
NICE crank!!! 80mm? 78? looks killer randal! no straight cut camgears? wassup with that LOL Good guess Aaron, it's an 80mm crank. The LN cylinders are 98mm. It should end up having a good deal of torque. And now after making a special offset key for the cam gear (to correct for the web cam inconsistencies) we can finally check the valve clearances and the other remaining issues. Anyway it's a happy day when progress is made. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 01:32 PM |
