how to remove dizzy gear?, FROM CRANK |
shaggy |
Jul 1 2006, 07:56 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
last night i got the 13mm bolt off of the end of the crank
i also was able to remove the impeller mount from the crank unsing a slide hammer i then removed the c ring from between the impeller mount and the dizzy gear but i do not know how to remove the dizzy gear. i dont want to use a screwdriver and risk damaging it and i know a slide hammer will trash it... i need to remove the dizzy gear to get the crank bushing off, unless there is another way that i dont know about... please help -jim |
bondo |
Jul 1 2006, 08:12 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
There is a special tool that hooks around the back of the gear and has a flat pad on a threaded shaft that screws against the end of the crank. It's pressed on.. You might be able to fashion something for a slide hammer that hooks around the back of the gear, but I wouldn't reccomend it. The tool is C shaped, with the ID of the "C" just the right size to fit behind the gear. The gear is on VERY tight. You might be able to rent a suitable puller.
ws91420 |
Jul 1 2006, 08:24 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Used a hydraulic press like one for wheel bearings off axle shafts to get mine off and used heat to reinstall it.
So.Cal.914 |
Jul 1 2006, 08:26 PM
I use a gear puller to get it off , I am sure you can rent one. To put it back on is a
breeze, use a map gas torch and heat it up it will slide right back on. Just make sure you seat it all the way up to the step on the crank. |
McMark |
Jul 1 2006, 09:13 PM
Iff'n yer handy, you can use heat to take it off too. Especially the distributor drive gear, that one's easy. Heat it up (I used Oxy-Acetelyne, but MAPP would probably work and propane might) and use a nice thick leather glove to pull it off, or use a screwdriver to apply light pressure. Once it's heater up it should come off pretty easily.
shaggy |
Jul 1 2006, 10:52 PM
Iff'n yer handy, you can use heat to take it off too. Especially the distributor drive gear, that one's easy. Heat it up (I used Oxy-Acetelyne, but MAPP would probably work and propane might) and use a nice thick leather glove to pull it off, or use a screwdriver to apply light pressure. Once it's heater up it should come off pretty easily. fire huh?...i like fire (IMG:style_emoticons/default/happy11.gif) so i need to remove all the oil first huh? thatd prolly be good im thinkin'... hopfully my friend will call me after he closes at his work tonight and tell me to come over so we can work through the night and it wont be 110* in the garage... thanks! -shaggy |
So.Cal.914 |
Jul 2 2006, 01:39 AM
Is the crank out of the case? If not I don't know if I would use fire, IMHO.
Thats what I get for assuming (IMG:style_emoticons/default/huh.gif) It was 117 here today, I was talking to a friend and he says " Yah but its a dry heat" so I respond " Yah so is fire". |
Lo-Fi Version | Time is now: 1st June 2024 - 10:38 PM |
