last night i got the 13mm bolt off of the end of the crank
i also was able to remove the impeller mount from the crank unsing a slide hammer
i then removed the c ring from between the impeller mount and the dizzy gear
but i do not know how to remove the dizzy gear.
i dont want to use a screwdriver and risk damaging it and i know a slide hammer will trash it...
i need to remove the dizzy gear to get the crank bushing off, unless there is another way that i dont know about...
please help
-jim
