how to remove dizzy gear?, FROM CRANK |
shaggy |
Jul 1 2006, 07:56 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
last night i got the 13mm bolt off of the end of the crank
i also was able to remove the impeller mount from the crank unsing a slide hammer i then removed the c ring from between the impeller mount and the dizzy gear but i do not know how to remove the dizzy gear. i dont want to use a screwdriver and risk damaging it and i know a slide hammer will trash it... i need to remove the dizzy gear to get the crank bushing off, unless there is another way that i dont know about... please help -jim |
Lo-Fi Version | Time is now: 18th May 2024 - 05:47 PM |
