Two random electrical questions, Brake and backup lights |
BMXerror |
Jul 2 2006, 04:38 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
First, I just put a side shift tranny in an early car, but the electrical connectors for the backup light switch is different. Can I put the old backup light switch in the new tranny, because it looks like it threads in the same way?
Also, I pulled my master cylinder to replace it today, and noticed that there are two wires coming down right by it. One connects to the master cylinder, but the other is just hanging. I assume that the one that hooks into the MC is for the brake lights and the ground is through the case of the MC. Right? Anyone know what the other wire is for? It's just got a push on connector just like the one for the brake lights. Thanks for putting up with my ignorance. Mark D. |
JPB |
Jul 2 2006, 08:23 PM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Cool question since I have just gone from a 17mm-19mm master and have only one wire connection on the new master. Whats there ta do?
BMXerror |
Jul 2 2006, 08:39 PM
Cool question since I have just gone from a 17mm-19mm master and have only one wire connection on the new master. Whats there ta do? Well, I've got a 17 and am going to 19, and both of them only have one connector. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) Mark D. |
So.Cal.914 |
Jul 2 2006, 08:49 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
The switsh on the M/C is not for your break lights it is to let you know if your M/C
fails (like you won't find out soon enough). I will look through my manual and edit this post. The wiring diagram shows a lead wire and a ground, sence I didn't know what year I went with a 71. I believe that you can use the old back up light switch on your new trans. Pull out and compare to make sure. |
BMXerror |
Jul 3 2006, 04:15 PM
Thanks So Cal... 'Take it out and compare' is kinda obvious, huh? I feel like a dumbass now. I was just wondering if there was any reason that they made the backup light switches on the early and late model trannies incompatable. I'll just try it and see if it works today. The year is 1970 BTW. Thanks again.
Mark D. |
JPB |
Jul 3 2006, 05:29 PM
Ya that break failing light shure is handy. Thanks for the info and will soon discard the extra schmit. Who deeds them wires anyways.
(IMG:style_emoticons/default/beer.gif) Grassyas! |
Lo-Fi Version | Time is now: 31st May 2024 - 05:56 PM |
