| Mueller |
Oct 9 2003, 11:42 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
I was weak....right after I sold my Pauter Roller rocker arms to Britain, I ordered a set of these (IMG:style_emoticons/default/smile.gif)
| Brad Roberts |
Oct 9 2003, 11:49 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
The car has to run to fully utilize those.
How about you commision me to get the engine together and in the car running and you do what you do (drawings/plans/idea's) B |
| Scott Carlberg |
Oct 9 2003, 12:16 PM
Porsche MOTORSPORTS ![]() ![]() ![]() Group: Members Posts: 1,595 Joined: 17-April 03 From: Modesto, Ca Member No.: 580 |
Mike,
those would be similar to these from GPR? http://www.gprparts.com/brands/gprStrutMou...ntKit/index.asp Dave/GPR showed these to me at the German AutoFest, they do alot of good, yes? |
| seanery |
Oct 9 2003, 12:18 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
those look like the ones given away at the ramble. They are the plastic bushing material.
| Brad Roberts |
Oct 9 2003, 12:23 PM
They work fine Scott for cheap replacement of the rubber. What they dont do very well is control the shock movement up and down. I'm sure they help a little over the stock rubber ones in the side to side department but I also want the shock to have precise control up and down.
B |
| JWest |
Oct 9 2003, 12:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,665 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None
QUOTE(Brad Roberts @ Oct 9 2003, 10:23 AM) They work fine Scott for cheap replacement of the rubber. They are not exactly cheap, though... |
| Mark Henry |
Oct 9 2003, 01:00 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
QUOTE(Mueller @ Oct 9 2003, 09:42 AM) I was weak....right after I sold my Pauter Roller rocker arms to Britain, I ordered a set of these (IMG:style_emoticons/default/smile.gif) They look a little too big to fit in your teen!!! (IMG:style_emoticons/default/wink.gif) |
| Brad Roberts |
Oct 9 2003, 01:02 PM
How much are they James ?? I didnt even look.
B |
| Mueller |
Oct 9 2003, 01:03 PM
$100 bucks........
Brad, give me a call, I've got a few questions for you regarding "M" and 914 calipers. |
| seanery |
120 ish
| Mueller |
Oct 9 2003, 01:08 PM
Hey B,
510.484.8700 cell.........I figured since you haven't called me back yet, you misplaced your phone or the batter is dead, LOL |
| J P Stein |
Oct 9 2003, 01:09 PM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
The Tarret jobbies are offset so's you can get more negative camber. Those other ones don't appear to do that.
| Brad Roberts |
I havent had my cell on since last Saturday. Its nice not taking phone calls.
B |
| JWest |
Oct 9 2003, 01:15 PM
I expected $50ish for the plastic jobs.
| Jeroen |
Oct 9 2003, 01:59 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
QUOTE(James Adams @ Oct 9 2003, 08:52 PM) They are not exactly cheap, though... Compared to the Tarett's they are (IMG:style_emoticons/default/biggrin.gif) cheers, Jeroen PS Mike, I'm still waiting for a delivery myself (IMG:style_emoticons/default/wink.gif) |
| URY914 |
Oct 9 2003, 02:18 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 133,158 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Are you just getting a piece of machined plastic for your $109.00?
Or is it installed in a housing? Paul |
| seanery |
Oct 9 2003, 02:20 PM
there is a cadplated sleeve
| URY914 |
Oct 9 2003, 02:26 PM
OK, your get a sleeve for the shock shaft to go thru AND a machined pieced of plastic.
Such a deal! Paul |
| Scott Carlberg |
Oct 9 2003, 02:27 PM
someone said:
"They are not exactly cheap, though... " & "Compared to the Tarett's they are" so, how much does the Taret set-up go for? |
| Jeroen |
Oct 9 2003, 02:35 PM
I think the Taretts go for sumptin like 450
Check www.tarett.com and look it up cheers, Jeroen |
Lo-Fi Version | Time is now: 24th May 2026 - 11:03 PM |
