Shift lever rotating |
Rand |
Jul 3 2006, 02:53 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Noticed my shift knob was getting closer and closer to my leg / steering wheel. Twisted on the lever and got it straight again. Now it's loosening up and rotates whenever I pull it into first.
In most cars I've had, the bottom of the shifter was flat or keyed so it couldn't rotate. I haven't had this one apart yet, so not sure what's supposed to hold it straight. How does it come apart? Three bolts at top of plate to pull it up? Linkage has to come loose? Any tech articles? Sorry for all the questions... I won't get a chance to look at it until tonight and just thought I'd fish for some tips ahead of time. (IMG:style_emoticons/default/beer.gif) |
Dr Evil |
Jul 3 2006, 03:10 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I bet you have a short shift kit. I have had this happen on two cars. The shift rod is JB welded into the ball in the shifter assembly. Check it out.
Brad Roberts |
Jul 3 2006, 03:17 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Or.. the locating pin broke.
More than likely a short shift kit that came loose. V |
Dr Evil |
Jul 3 2006, 03:18 PM
(IMG:style_emoticons/default/agree.gif) or that
Cap'n Krusty |
Jul 3 2006, 04:06 PM
There IS no locating pin. And the factory glued the shifters, too. The Cap'n
ClayPerrine |
Jul 3 2006, 04:07 PM
Life's been good to me so far..... Group: Admin Posts: 15,490 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There IS no locating pin. And the factory glued the shifters, too. The Cap'n (IMG:style_emoticons/default/agree.gif) I just reglued mine in a couple of weeks ago. |
So.Cal.914 |
Jul 3 2006, 04:11 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Correct. There is no pin. To remove it use Mapp gas or propane heat the base
and what's left of the epoxy will let go. Clean the leftovers out of the base and lever and re epoxy the lever into the base, use the epoxy liberialy and let cure. |
Rand |
Jul 3 2006, 04:14 PM
What kind of glue do you recommend? I haven't had it out yet to look at the bottom, but as snug as the sides are it seems like something thin would be needed?
Rand |
Jul 3 2006, 04:16 PM
Oops... Socal got a post in before mine. So epoxy then.
Dr Evil |
Jul 3 2006, 04:25 PM
Really, well I had a few that were welded in......except for the two that had short shift kits on them. I did not know they were ALL glued in.
Llive and learn. |
rhodyguy |
Jul 3 2006, 04:41 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
don't torch it with the lever still in the base. while it's apart replace the bushings that cradle the lever ball. cover the springs for the R/1 detent plate with a rag when you pull the pins and remove the springs. the springs like to fly. undo the bolt that secures the bottom of the lever to the front rod when you pull the shifter. leave the front rod end connector alone so you don't lose the linkage adjustment.
k |
Rand |
Aug 10 2006, 03:42 PM
Ok, no exciting news or anything, but thought I would post an update just because I like it when people do that. A lot of threads are started because we have a question, but the most valuable posts are the ones with the answers. Anyway...
I was surprised to learn the shifters are simply glued into the ball with no pin or anything. Mine was loose, so I just twisted it back and forth while pulling up and it came right out. It doesn't look like a short shift kit, but it does look like it was previously glued with some kind of plastic-like epoxy. At my first glance, the color of that plastic made me wonder if the ball was nylon or something... but seeing everything was steel, I went ahead with the JB Weld fix. Wire wheeled the rod clean, sanded out the hole with a small wheel, vacuumed and wiped with solvent on a rag poked in there. Spread the JB Weld mixture thinly around the rod and wiped the excess off in the hole. Put it together, working around and positioned the shifter at the angle I wanted.... Done deal. Good as new. |
Lo-Fi Version | Time is now: 29th May 2024 - 01:47 AM |
