Fundamental question, Should be easy, but isn't this time |
jd66921 |
Jul 5 2006, 10:52 AM
Member Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 |
Okay, I got my car running again, sort of....
But, I have a problem I can not figure out. One cylinder is cold. #2 cylinder is dead. I pulled the plug, and is is wet with gas. I switched the wire. I switched the plug. The plug fires out of the cylinder. The injectors were tested. There is compression. In the same vein, I am not getting good vacuum, so the airflow sensor is not opening enough to keep the car running. Would a nonfiring cylinder cause that? Will I pull more vacuum with them all running? I can not find any more vacuum leaks. I've been through them all a few times. Anybody have any ideas? I'm getting excited again!! Thanks, Jeff |
Brad Roberts |
Jul 5 2006, 10:56 AM
You say there is compression: how much?
You have a leaking injector What is the fuel pressure? B |
jd66921 |
Jul 5 2006, 11:20 AM
You say there is compression: how much? You have a leaking injector What is the fuel pressure? B Compression is around 100 cold. I can't get the car running long enough to do it hot. #3 and #4 are slightly lower and thay run. This problem started before I had the injectors cleaned and tested. The injector has since been swapped. Fuel pressure is about 30 psi. The problem I fixed was that the fuel pump had been running all the time. The contact in the airflow sensor was shut all the time. It was also cutting out, and I think that was related to the bent pump contact. This was a running engine before I drove it from California to Texas two months ago. Otherwise, the airfllow sensor is unmolested. Jeff |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:03 AM |
