Rear Pagid Orange Brake Pads, Don't fit... |
yeahmag |
Jul 6 2006, 11:43 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I've got some (used) Pagid Orange pads for the rear of my '74 and they don't fit the pins. On my car (and in the book) there is a big retaining pin and a small retaining pin. These pads seem to only fit the small side - similar to how a front pad would work. That being the holes in both ears are the same size.
I double and triple checked with the seller that they are for my car and in his defense in checking Pelican's site it seems all the 914's use the same rear pad. Any ideas? (IMG:style_emoticons/default/WTF.gif) -Aaron |
bd1308 |
Jul 6 2006, 11:44 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
cut a larger hole for the big pin?
b |
echocanyons |
Jul 6 2006, 11:46 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I have had the same problem with a few different types of pads like ferrodo etc.
I use a file to enlarge the small hole, dont see that this would ever cause a problem doing this but it is a pain in the but. I've got some (used) Pagid Orange pads for the rear of my '74 and they don't fit the pins. On my car (and in the book) there is a big retaining pin and a small retaining pin. These pads seem to only fit the small side - similar to how a front pad would work. That being the holes in both ears are the same size. I double and triple checked with the seller that they are for my car and in his defense in checking Pelican's site it seems all the 914's use the same rear pad. Any ideas? (IMG:style_emoticons/default/WTF.gif) -Aaron |
yeahmag |
Jul 6 2006, 11:47 PM
Is it not odd that the previous guy apparently didn't have this problem? Are there different rear calipers out there for our cars?
-Aaron |
echocanyons |
Jul 7 2006, 12:05 AM
I think the pads (not the calipers) cross reference to a VW bus.
Yes, I agree that is strange but it may be possible that he was using two small pins on each caliper with enough resistence from the clip so they didn't move. FWIW The PET and Porsche classic show only one rear L and one rear R caliper for the /4. They do show two different part numbers for the pins suggesting different sizes. This doesnt mean that the other caliper # couldn't have been supraceded. I wouldn't think they would change it just for the pin diameter. I am surely not an expert on the stock rear brakes maybe Eric Shea would know for sure. |
Aaron Cox |
i have heard you need to oblong the hole.....
yeahmag |
Jul 7 2006, 01:14 AM
OK. Got one of four filed to fit (by hand). Time to buy a dremel bit...
Thanks! -Aaron |
anthony |
Jul 7 2006, 01:27 AM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Wear a mask. Don't breath that stuff.
So.Cal.914 |
Jul 7 2006, 02:29 AM
Carbide bit and a Dremel, 5 minutes.
Van914 |
Jul 7 2006, 04:57 AM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
Yes, you have to enlarge the hole. Just drill it out. I have used these pads for years and they are great on the track. A little squicky at times and a lot of brake dust. I have new sets of front and rears for a 914-4 for sale if anyone is interested. I changed calipers and can't use them any more. $90 a set shipped.
Thanks Van |
Lo-Fi Version | Time is now: 28th May 2024 - 05:38 PM |
