doors wont lock from outside..., what am I doing wrong? |
dflesburg |
Jul 13 2006, 10:53 AM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
Doors work fine except I put the key in, turn it, remove it and doors don't lock
Must be something I am doing wrong. |
BMXerror |
Jul 13 2006, 12:30 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Doors work fine except I put the key in, turn it, remove it and doors don't lock Must be something I am doing wrong. I had this problem too until I realized that I was turning it the wrong way. (IMG:style_emoticons/default/headbang.gif) Might be something to check. (IMG:style_emoticons/default/biggrin.gif) Mark D. |
Dr Evil |
Jul 13 2006, 05:53 PM
The end of the lock cylinder has a square protuberance sticking out of it that engauges the arm that engauges the lock plate thing. If this square part rounds off (common, I have one with this problem, its how I know) then it will not work .
Easy check, just remove the door handel, put your key in and twist. |
URY914 |
Jul 13 2006, 07:48 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,017 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
See the little pot metal "nipple" at the bottom of the handle? If this breaks: no lockie-lockie. If you need one, I'll give you one.
Attached image(s) |
hbh |
Jul 17 2006, 11:24 AM
Newbie Group: Members Posts: 3 Joined: 17-July 06 From: bellingham, wa Member No.: 6,454 |
i had the same problem too...i took the interior door panel off and sprayed all the parts down with silicon spray, took the interior latch a little loose and "adjusted" the entire system until i got it all to work. the first time i got the key to work then the interior lock wouldnt come off, so i kept fussing with the adjustment until now both the key and the interior lock work together. I was turning the key the wrong way on the door lock also to start with....now both doors work fine with the key...with just a fraction of an inch adjustment on the long arm that connects the exterior door lock to the interior door lock and a little silicone it all functions properly
Lo-Fi Version | Time is now: 7th June 2024 - 04:08 PM |
