914 engine in a 356, Which is best to start with? |
PH356 |
Jul 13 2006, 01:46 PM
Newbie Group: Members Posts: 1 Joined: 13-July 06 From: Minneapolis Member No.: 6,428 |
I need some information from the 914 knowledge base here. I'm planning on building up a 914 engine to put in my 356 for DE events. More HP. More Torque, better reliability, etc. I'm thinking about building it up to about 2100-2200cc. Any recommendations on which case to start with? Or are they all about the same?
What differences are there if any to VW type IV cases? I'd also be interested in any recommended reading to pick up. Thanks, Phil Minneapolis |
G e o r g e |
Jul 13 2006, 01:53 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
cases are the same, basically. check out shoptalkforums type 4 board you can get a lot of info from people using type4 in these scenarios.
ptravnic |
Jul 13 2006, 02:15 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
For your power range there is a tried and true 2056cc & 2270cc.
McMark |
Jul 13 2006, 02:20 PM
Hey Phil. (IMG:style_emoticons/default/welcome.png)
I think you're the guy Mike Zois was talking to, right?. (IMG:style_emoticons/default/wink.gif) The cases are the same, usually bus cases are beat to hell and have the oil filler at the bottom of the case instead of on the top. A properly set up 2056 will net you 125 hp or so and a properly set up 2270 can get you up around 170-180 hp. (IMG:style_emoticons/default/ohmy.gif) If you want to build it yourself, I recommend the kits that Jake Raby sells. They take all the guess work out of the parts purchasing process. You literally get a box of parts and just start putting things together. Easy easy. |
maf914 |
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
cases are the same, basically. check out shoptalkforums type 4 board you can get a lot of info from people using type4 in these scenarios. (IMG:style_emoticons/default/agree.gif) The type 4 and aircooled technology forums at shoptalkforums.com are a good source of info. Spend some time there and learn what people with the big four build-ups and conversions. |
Lo-Fi Version | Time is now: 6th June 2024 - 01:32 PM |
