has any one changed front motor mounts, in the car |
messix |
Jul 13 2006, 06:12 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
i felt a bumping under acceleration. with some looking around and under i found both front mounts [the little rubber thingies] .
so any stories? |
MartyYeoman |
Jul 13 2006, 06:19 PM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Broke both of mine in half.
They can be changed out without too much trouble. |
BMXerror |
Jul 13 2006, 06:20 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Allan |
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
They can be changed out without too much trouble. (IMG:style_emoticons/default/agree.gif) I've done it... |
Bruce Allert |
Jul 13 2006, 06:23 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
Broke both of mine in half. They can be changed out without too much trouble. Ya, well kind of... actually I think it's a beotch to change. I've got 2 under my belt & the 2nd time "was" easier. Just support the engine & loosen/ lower the engine bar. Yer gonna find not much room get'n at dem nuts to take out the old & put in the new. Have fun (IMG:style_emoticons/default/biggrin.gif) & make sure ya gots lots of Fat Tiar!!! (IMG:style_emoticons/default/drunk.gif) .......b |
BMXerror |
Jul 13 2006, 06:29 PM
I've had my car three months, and haven't even driven it yet, but I've done it three times. If you're talking about the outside ones, it's cake(I don't know if you have an early or late motor mount). The inner mounts are a PIA, but you can get it if you're patient. It's just hard to get in between the brackets and the fan shroud to put the nuts on. Give yourself about an hour for each top nut, and you'll be fine!
Mark D. |
messix |
Jul 13 2006, 06:32 PM
i've got them out, and the one click at a time is a pain!
Dave_Darling |
Jul 13 2006, 07:19 PM
Amen to that! I found access was a bit easer if I removed the oil filter, IIRC. And install the mounts onto the brackets on the crankcase first, then install the motor mount bar. Only took me a couple of tries to figure that latter one out...
(Yes, I was blonde at the time. (IMG:style_emoticons/default/wink.gif) ) --DD |
messix |
Jul 13 2006, 09:16 PM
got-r-done!
after rich got [swam 'cause raining and he rode his motorcycle today, what was he think'n] home and gave me the one's he had for the LE project that i will replace with new ones, b.s'd for a bit and got back home and got er together. yes D.D. i figured that out right away. and dan if yer lurkin' droping the motor down a bit didn't help much, cause the fan shroud was still in the away to get to the mount on the engine. this one i don't want to repeat, but didn't seem as bad as a valve lash in car. |
Lo-Fi Version | Time is now: 7th June 2024 - 07:20 AM |
