Rear Hub Question, is it safe? |
brer |
Jul 17 2006, 10:22 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
Ok, so is it cool to bolt wheels to my rear hubs without the stub axle bolted in?
One of the hubs has a little movement, new bearings, and it kinda makes me think that it needs the stub axle bolted in it. no bearing problem there is there? I mean... should they be solid Tight like they are when assembled? or will they pull up tight with the torque of the axle nut. |
tomamafone |
Jul 17 2006, 10:24 PM
There's no "I" in Teener Group: Members Posts: 109 Joined: 7-January 05 From: Hollywood, CA Member No.: 3,414 |
I think you run the risk of destroying the bearing if you put the weight of the car on it w/o the axle stubs... am i right guys?
Series9 |
Jul 17 2006, 10:26 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Yep, if you roll the car on the bearings without the nut fully tight, you will likely damage the bearings.
brer |
Jul 17 2006, 10:29 PM
muchos gracias.
I kind of thought that looking at the bearings. One has a little IN-out movement, is that normal with no stub axle? are they that delicate? or is it just the weight of the car. |
Aaron Cox |
Jul 17 2006, 10:45 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
new bearings tend to have slop... pulls in fine (i think torque on stub nut is 200+)
SKF's are loose, but pull in nice. must have stubs inside hubs, or your bearings are toast with the cars weight on em |
brer |
Jul 17 2006, 10:50 PM
Yes SKF's on it.
ONe seems firm, the other is kinda loosy. a little in-out, a little up-down. Makes me worry. |
Aaron Cox |
Jul 17 2006, 10:56 PM
Yes SKF's on it. ONe seems firm, the other is kinda loosy. a little in-out, a little up-down. Makes me worry. torque it in (IMG:style_emoticons/default/smile.gif) |
brer |
Jul 17 2006, 10:59 PM
I left the axles on the tranny when i pulled it.
Today, I tried to remove the axle bolts by meself... all I managed to do was get axle grease up to my elbows. thing kept turning and slipping and i"m like, trying to hold one bit and get some fear on the bolt, which of course just turned the axles. Not one bolt came loose. fun. (IMG:style_emoticons/default/beerchug.gif) Hence the question about moving it without the stubs in. |
Demick |
Jul 18 2006, 08:20 AM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
How the hell did you remove the tranny with the axles attached to it? Seems like a near impossible feat to me.
Allan |
Jul 18 2006, 08:25 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
How the hell did you remove the tranny with the axles attached to it? Seems like a near impossible feat to me. (IMG:style_emoticons/default/agree.gif) |
brer |
Jul 18 2006, 09:21 AM
removed the suspension first.
Lo-Fi Version | Time is now: 1st June 2024 - 10:45 AM |
