4 megasquirt threads in the 1st 18 on the page!, Come on guys, READ the page |
Cap'n Krusty |
Jul 18 2006, 08:46 PM
Not much reason I can see for 4 threads running at the same time on what is basically the SAME topic! S'pose we could piggyback some of the stuff so we don't have to run all over the list trying to keep up with the topic? The Cap'n, grumpy as ever.
yarin |
Jul 18 2006, 08:49 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
Yea blame me....
I've been off the boards for a while and just did a quick megasquirt search and responded with my $0.02. Also a bit excited that I finally can say my project was a success. (IMG:style_emoticons/default/drunk.gif) |
crash914 |
Jul 19 2006, 05:26 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Yarin, so what did you find out was the problem?
how is it running now? |
Qarl |
Jul 19 2006, 06:23 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
What's a Megasquirt? Will it work with my new 911? (IMG:style_emoticons/default/biggrin.gif)
crash914 |
Jul 19 2006, 06:29 AM
only if its yellow and you use 2 coats of wax
yarin |
Jul 19 2006, 07:42 AM
Yarin, so what did you find out was the problem? how is it running now? Hey Herb, I don't even know where to start, a series of things that led me in a loop. After discovering and solving a stuck open injector, stuck closed injector and had all the injectors cleaned again I found my injector bank problem. There was a flux bridge on the active flyback circuity of one channel. The weird part was the signal looked perfect on a scope using the stim, but when loaded the output was bad. So that was one issue. I chased that issue for at least two months. The turning point came one day when my brother was helping me out. I still couldn't get the idle to stabilize, it run cycle up and down from 900-1200rpm. He suggested taking the car out for a drive, so i bit the bullet and let it loose. Ran like crap for the first two minutes, bucking, sputtering, then after two minutes of either burning something in or AUTOTUNE it magically smoothed itself out. I did a minimal amount of tuning since I used someone else's tables. After all that I ahd a bunch of non-MS issues to solve, brakes, loose shifter rod, loose rocker/valve bolt, etc etc.. small stuff u know. I can finally proudly say that the car is running reliably. I haven't setup TPS-accel and spark is still handled by the dizzy advance. However it starts up all the time, runs almost perfectly! Car finally shifts nice, i think its pretty much ready for autox! I lost hope a times and got busy with other stuff like starting my MBA and whatnot. But I stuck through it and have something to show for it. I hope to put up a site sometime soon with a build plan, material list, how to and all of that stuff. Thanks for your help! |
brownaar |
Jul 19 2006, 08:08 AM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
Gint |
Jul 19 2006, 09:18 AM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Not much reason I can see for 4 threads running at the same time on what is basically the SAME topic! S'pose we could piggyback some of the stuff so we don't have to run all over the list trying to keep up with the topic? The Cap'n, grumpy as ever. Good work! (IMG:style_emoticons/default/smilie_pokal.gif) Now there are 5 threads on the subject. |
Lo-Fi Version | Time is now: 8th June 2024 - 03:23 AM |
