Tire size choices?, 185/70/15 vs. 205/60/15 |
boston914 |
Jul 20 2006, 03:17 PM
Member Group: Members Posts: 52 Joined: 15-July 03 From: Boston, MA Member No.: 912 |
I need some quick opinions on a tire choice.
I am currently running Pirelli P6 tires, size 185/70 VR15 on my Mahle wheels. I am having my recently polished 2.0 Fuchs rims mounted tomorrow. When I bought the wheels, they came with four Goodyear NCT 205/60 VR15 tires. Both sets of tires are in excellent condition with minimal wear. Can anyone give me any help deciding which ones to mount on my Fuchs? Thanks! **************************************** '76 Malaga Red |
lapuwali |
Jul 20 2006, 03:31 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Will the 205/60s fit on the rear without rubbing? It's likely to be pretty snug.
STL914 |
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
When I had my 2 liter Fuchs, I ran 205/60 HR15's and had no clearance problems
with the rear fenders. |
anthony |
Jul 20 2006, 03:46 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
If the 205-60s don't fit 195-60 is a good option for a street car.
boston914 |
Jul 20 2006, 03:55 PM
I am not sure if the 205s will fit my fenders.
I am trying to avoid paying for mounting and balancing, then have to dismount again if they don't fit. Any comments on the tire brands/models that I have? Pirelli P6 vs. Goodyear NCT |
lapuwali |
Jul 20 2006, 04:14 PM
Unfortunately, just because tires of size X fit on 914 A, that doesn't mean different tires of size X will fit on 914 B. Tire sizing is very approximate (width can vary by a LOT from one model of tire to another, even if the size is "the same"), and the rear fenders on a 914 vary by a lot from car to car.
There's really no way to know without trying them. 205/50s fit on many 914s, but not all 205/50s, and not all 914s. 205/60 is pushing it. It may fit fine. It may not. I've been a fan of P6s for awhile, but they're a fairly old design now. They just started to make P6s again after a long layoff. If they're old P6s, I'd worry about them being too old. Tires degrade from oxidation over time, even if they have good tread. I've had to throw away plenty of tires that had plenty of tread, but were in dangerous condition, anyway. Look carefully at the sidewalls near the bead for cracks. If the tires are unmounted, try bending the sidewall to check for cracking. |
Toast |
Jul 20 2006, 05:12 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
Unfortunately, just because tires of size X fit on 914 A, that doesn't mean different tires of size X will fit on 914 B. Tire sizing is very approximate (width can vary by a LOT from one model of tire to another, even if the size is "the same"), and the rear fenders on a 914 vary by a lot from car to car. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) I'm running 205's on front and rear. I had Remmington's. But the fronts wore to the cords on the inside due to mis-alignment. I had no clearance problems. But, the BF Goodrich tires that were put on the fronts Do Not clear even though they are the same "size" as the rear. They have raised the front so I no longer have a good visual over the steering wheel. They rub on the inside if I make a sharp turn. Plus they are UGLY!!!! (IMG:style_emoticons/default/icon8.gif) (IMG:style_emoticons/default/owned.gif) Of course they are 5000 mile tires. (IMG:style_emoticons/default/dry.gif) Think I will put them on the rear so that can burn em off faster. (IMG:style_emoticons/default/burnout.gif) |
MecGen |
Jul 20 2006, 07:16 PM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hi
I had 195/60 for 15 years....love that size for the street (IMG:style_emoticons/default/boldblue.gif) It always just seem to be a good comprimize between comfort and performance. Look real good too. (IMG:style_emoticons/default/wub.gif) and garrentied to fit, I have a set of 205/50 that rub on the 73 but not the 74 (IMG:style_emoticons/default/confused24.gif) My 74 is mostly bone stock (carbed and cammed) and the tires can handle anything I could give them, or want to give it, but I am very carefull with Blue.... Later (IMG:style_emoticons/default/beerchug.gif) |
john grier |
Jul 20 2006, 07:27 PM
Member Group: Members Posts: 303 Joined: 27-June 04 From: Hermitage, Tn Member No.: 2,265 Region Association: South East States |
My 205 60 15 michlins chirp,
They ride fine, handle fine for street but they chirp All I here is chirp, chirp here chirp there, it gets anoying. |
So.Cal.914 |
Jul 20 2006, 09:03 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
On my 72 I run 205/ 55/15's, no rubbing on front or back.
rickyhgarcia |
Jul 20 2006, 09:11 PM
UPS truck is here... Group: Members Posts: 293 Joined: 13-June 04 From: Miami, Florida Member No.: 2,198 |
I have Yokohamas 205/50-15 mounted on 5-lug (15x6) Fuchs all around with no rubbing. Problem is I am off by about 10% on the speedometer.
I am thinking, however, to replace them with 195/60 or 195/65 to solve the speedometer problem. |
Toast |
Jul 20 2006, 10:33 PM
(IMG:style_emoticons/default/laugh.gif) Then you will be 10% off on the odometer.
Toast |
Jul 20 2006, 10:34 PM
My 205 60 15 michlins chirp, They ride fine, handle fine for street but they chirp All I here is chirp, chirp here chirp there, it gets anoying. Maybe you should try taking the corners softer. (IMG:style_emoticons/default/biggrin.gif) |
jimtab |
Jul 20 2006, 11:25 PM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
I have 205-50 Falken Aenzis on my stock fuchs and I LOVE them...sticky, sticky, sticky...fit fine....no flaring at all...
Joe Bob |
Jul 20 2006, 11:42 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
I've run with 205/50s....really gives a boost quickness wise. The speedo was fer shitz though....
jimtab |
Jul 21 2006, 06:47 PM
I've run with 205/50s....really gives a boost quickness wise. The speedo was fer shitz though.... (IMG:style_emoticons/default/agree.gif) Get's to be kinda by guess and by golly.... |
ovilla |
Jul 22 2006, 11:10 AM
Member Group: Members Posts: 84 Joined: 25-February 05 From: Plainfield, IL Member No.: 3,660 |
I'm running 195/60 Yok AVS-I's and they are a nice sticky street tire. The other 914's got 205/50 BFG's and I think I like them a little bit better. Just something about the lower profile that helps in cornering speeds.
Tobra |
Jul 22 2006, 03:43 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
I'm running 195/60 Yok AVS-I's and they are a nice sticky street tire. The other 914's got 205/50 BFG's and I think I like them a little bit better. Just something about the lower profile that helps in cornering speeds. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) I have the same size yoko's, I have been told(Martin) that 185-65 are nice, as they are very close to stock diameter and don't have as much sidewall flex, presumably because the tire is not stretched so much on the rim. The 195-60 bulges quite a bit, asa shown in the pic. This is on one of the 4 lug Fuch wheel, but it is the same dimension wheel. Don't have a shot showing how much it bulges, but I would think a 205 would be too much by seeing how a 195 looks. This is a 195-60 next to a stocker Attached image(s) |
914rat |
Jul 24 2006, 01:59 PM
Member Group: Members Posts: 279 Joined: 3-July 06 From: Maryland Member No.: 6,362 |
Ihave 205 /60 Pirelli's on my stock Fuchs , and think I could fit 215 60's if I rolled the fender lip.
Van914 |
Jul 24 2006, 02:35 PM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
I too run the Yoko AVS in 195X60X15. Great tire for the street and when my Victoraces gave up last week at the track they worked good.
van914@aol.com |
Lo-Fi Version | Time is now: 10th June 2024 - 11:47 AM |
