Pictures of your engine mounts please, Other engine conversion guys |
soloracer |
Jul 21 2006, 12:02 AM
Senior Member Group: Members Posts: 793 Joined: 7-April 03 From: Calgary Member No.: 538 |
I was wondering if you guys would mind posting pictures of the engine mount/subframe assemblies that you used to mount your engine of choice into a 914. V8, Audi, Subaru, you name it I would like to see it. My rotary engine has two mounts that are towards the rear of the engine. It looks like the strongest place to mount an engine bar would be on the stock 914 mounting points near the front of the trailing arms. I'm just wondering how you guys did it. I'll be sure to post pictures of the progress being made on my car. Thanks.
banksyinoz |
Jul 21 2006, 12:28 AM
finally getting back into it Group: Members Posts: 223 Joined: 17-June 05 From: queensland, aus Member No.: 4,293 Region Association: Australia and New Zealand |
hey there you might want to use both the side mounts from the later / your engine and also source a front cover from an earlier 12a or 13b with the front mounting points the are all similar aqnd all the oil pump assembly will fit, major diff is the water pump u will have to use an older pump , this is the process we have used on the new engines in the old cars r1oo rx2+3 etc the engine in the pic (that u have seen before ) has a plate from the front to the centre plate with the bearing carrier to help stop the flex at the crank/eccentic shatf at this piont i would love to see this rocket in action (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
soloracer |
Jul 21 2006, 08:53 AM
We thought about that and we also thought about putting a baffle plate in the oil pan with ears that stick out past the pan that could be used as mounting points. Thanks for the photo.
Lo-Fi Version | Time is now: 9th June 2024 - 05:51 AM |
