74 2.0 Fuel injection, Should I change back??? |
bumblebee74 |
Jul 22 2006, 09:14 PM
Newbie Group: Members Posts: 10 Joined: 21-July 06 From: oklahoma Member No.: 6,480 |
The original owner of my bumblebee had removed the fuel injection on the engine and replaced it with a single carb. Should I change back to the fuel injection? and if so, where could I find a kit to install? I am new at this and grasping for information.
Thank you. |
brant |
Jul 22 2006, 09:17 PM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The original owner of my bumblebee had removed the fuel injection on the engine and replaced it with a single carb. Should I change back to the fuel injection? and if so, where could I find a kit to install? I am new at this and grasping for information. Thank you. There isn't really a "kit" out there. you may find someone selling an entire unit. or else you will need to research the different components and piece together all of the bits and pieces. its not impossible. and not really that hard to understand either. but plan on doing some research and then looking for part after part. brant |
So.Cal.914 |
Jul 22 2006, 09:29 PM
Was other work done (like a new cam) to the engine? Two carbs are better than one.
Bleyseng |
Jul 22 2006, 10:39 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
If people put on a single carb it means they are too lazy to do anything right IIHO. Bet everything is still stock so a reinstall of the FI would be pretty easy once you locate the parts. I did it now 10 years ago.
bumblebee74 |
Jul 22 2006, 10:40 PM
bumblebee74 |
Jul 22 2006, 10:46 PM
If people put on a single carb it means they are too lazy to do anything right IIHO. Bet everything is still stock so a reinstall of the FI would be pretty easy once you locate the parts. I did it now 10 years ago. Do you happen to know anyone/anywhere with a complete unit that would work? I assume it was the Druk-Jetronick that was on the Bumblebee. |
bumblebee74 |
Jul 22 2006, 10:48 PM
The original owner of my bumblebee had removed the fuel injection on the engine and replaced it with a single carb. Should I change back to the fuel injection? and if so, where could I find a kit to install? I am new at this and grasping for information. Thank you. There isn't really a "kit" out there. you may find someone selling an entire unit. or else you will need to research the different components and piece together all of the bits and pieces. its not impossible. and not really that hard to understand either. but plan on doing some research and then looking for part after part. brant I asked Geoff this as well. Do you happen to know anyone/anywhere with a complete unit that would work? I assume it was the Druk-Jetronick that was on the Bumblebee. |
Bleyseng |
Jul 22 2006, 10:55 PM
Post an ad in the Classifieds as I have one but its for another motor.
Rand |
Jul 22 2006, 11:57 PM
The stock fuel injection system is definitely superior to a single carb setup.
If you want to put the time and money into converting back to FI, I think you have two logical options: Find a bargain on a complete original system (which is possible around here), or go with a modern system. I like the original systems, but they are old. Which means you could get bit with a bad part that is very difficult to find or expensive to repair/replace (such as an MPS). Modern systems are available. If you like a do-it-yourself project, then I think Megasquirt is the way to go. If you're not so much into DIY, then maybe spend some more and look at SDS. If I was starting from scratch, I would definitely go with a modern system. If you are ever thinking about building a hotter motor than stock, then for sure go with a modern system. By the way, air conditioning was not a factory option. It was installed by some dealers or private parties. |
TJB/914 |
Jul 23 2006, 05:59 AM
Mid-Engn. Group: Members Posts: 4,336 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Bumblebee74
Good advise from everyone. My suggestion to you is your personal choice, do I want to keep my 914 F.I. stock or modify with another F.I. system. It will cost you 0??? to $1,000 dollars to find a complete working D-Jet F.I. sytems. The heart of the system is the MPS which could be the major purchase for a good one. Here's a picture showing a complete system from my spare parts stash. Use this as a guide to find individual pieces. Happy hunting. Tom Attached image(s) |
bumblebee74 |
Jul 23 2006, 07:43 AM
Bumblebee74 Good advise from everyone. My suggestion to you is your personal choice, do I want to keep my 914 F.I. stock or modify with another F.I. system. It will cost you 0??? to $1,000 dollars to find a complete working D-Jet F.I. sytems. The heart of the system is the MPS which could be the major purchase for a good one. Here's a picture showing a complete system from my spare parts stash. Use this as a guide to find individual pieces. Happy hunting. Tom Thanks Tom. |
Bleyseng |
Jul 23 2006, 08:01 AM
Pic of a complete Djet 2.0l motor so you know how it should look.
Attached image(s) |
brant |
Jul 23 2006, 08:34 AM
bumblebee,
I don't know of any sets personally. but parts cars come along pretty often. likely if you buy cheap something may be bad or worn and you will still end up looking for at least 1 individual part or more. either way, If you fiddle with what you have your going to have to learn induction inside and out. Its not that bad..... kinda interesting. also, since your going by "bumble bee" I wonder if your car isn't a black and yellow LE model. If it is, those cars are really escalating in value. Certainly if you were going to sell a decent condition LE it should bring a bit more in resale with a functioning F.I. on it, than it would with a single carb. I guess what I'm saying is that if you spend $ on finding the parts you would probably recover 100% of that money in resale. brant |
TJB/914 |
Jul 23 2006, 09:29 AM
Bumblebee,
Brant just said what I should also have said (Wise advise from an expert). Here's a picture of the MPS the heart of the D-Jet F.I. System. Bleyseng (Geoff) is the MPS expert and the daddy of replacement MPS's. Give him a call for a replacement & get on his list. If you find one he is the MPS person to send to for repairs/evaluation. I believe the MPS should end in #43 to be correct for your 1974. Start with this MPS piece & everything else is easy. Geoff: Hope you don't mind the sales presentation. Tom BTW: Forgot to plug Jeff Bowlsby for the replacement wiring harness. Did I forget anyone??? Didn't I see an advertisement in the parts section from Mark selling off F.I. parts??? Attached thumbnail(s) |
Bleyseng |
Jul 23 2006, 01:43 PM
Usually people take the Djet FI off for either a bad FI wiring harness (goofy shorts so it runs bad) or a bad MPS (too rich) and they can't pony up the money for a new NOS one. AA ones atleast the ones I have seen in the last two years had soldered diaphrams (kills throttle response). Brett Ins used to rebuilt them nicely but calibrated all of them to 1.7L specs (not good for 2.0L).
Slowly look around for a complete setup |
bumblebee74 |
Jul 23 2006, 02:30 PM
Everyone here is wonderful. It is a 74 914 LE "bumblebee" Hence the name. I am wanting to go back 100% original. Currently I am on a "slow start" income but that should change. It has a wrecked front end and the changes I have mentioned above. How detrimental would it be to replace the wrecked body parts with another vehicles body?
Bleyseng |
Jul 23 2006, 03:45 PM
Depends on the parts...most can be repaired or replace with used parts fairly easy. The problem is to keep the tub straight or have it checked/or corrected if its twisted.
Check SirAndys threads on the straightened he had done on his red car and the 'six" tub that was wrecked/twisted. |
JeffBowlsby |
Jul 23 2006, 06:37 PM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Brian?
If you are trying to obtain its highest value AND keep it original, the D-jet is the only answer. Everything is available. |
StratPlayer |
Jul 24 2006, 01:41 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
The original owner of my bumblebee had removed the fuel injection on the engine and replaced it with a single carb. Should I change back to the fuel injection? and if so, where could I find a kit to install? I am new at this and grasping for information. Thank you. There is a 2.0 FI setup for sale on ebay now. http://cgi.ebay.com/ebaymotors/Porsche-914...011517241QQrdZ1 |
fast914 |
Jul 24 2006, 02:10 PM
Newbie Group: Members Posts: 16 Joined: 4-May 06 From: USA Member No.: 5,975 |
I'm rebuilding my 2.0L engine, there is a good chance I'll switch to a 944NA EFI (DME, Harness,...). Once the decision is made (in couple of weeks), a good running 2.0L FI will be for sale (harness, ECU, etc...).
I'm upgrading to 96mm P/C and a webcam 86.. It all depends on how the FI runs.. |
Lo-Fi Version | Time is now: 12th June 2024 - 04:39 AM |
