Help - I am so close to getting it running again ..., I am not getting any fuel?? |
vesnyder |
Jul 23 2006, 04:31 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I am not sure I have the fuel lines correctly hooked up? The feed line comes from the tank, goes to the pressure regulator, then the drivers side fuel rail. Out of this rail through a connector on the motor (which has an electrical connector) then to one side of the passengers side rail. On teh opposite side of teh passengers side fuel rail is the return line to the pump - sound right?? If so, what other potential issues might there be? I will check the fuel pump next! I am so close I can hear it !!!
bondo |
Jul 23 2006, 05:05 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I'm pretty darn sure that the pressure regulator goes after the fuel rails. The regulator should be the last thing before going up front to the tank.
Cap'n Krusty |
Jul 23 2006, 05:12 PM
Yup. The regualtor keeps the pressure at the desired number taking into account all the demands by "consumers" (injectors). It does so by only allowing fuel in excess of the needs of the engine to pass through. The Cap'n
vesnyder |
Jul 23 2006, 05:22 PM
Sounds good. I will have to give that a try! Stay tuned!
URY914 |
Jul 23 2006, 06:54 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,091 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Be sure those hose clamps are TIGHT!
Ever had gas in your eyes? I have. Hurts bad. |
vesnyder |
Jul 23 2006, 06:55 PM
Fixed the fuel supply, but still no luck keeping it running? I am pretty sure it gets spark because when I use starter fluid it runs momentarily. What is the next logical problem area - injectors? I double checked the control panel connections - anything typically missed or that goes bad?
bondo |
Jul 23 2006, 07:36 PM
Do you hear the fuel pump run for a second when you first turn on the key? If not, start with that.
vesnyder |
Jul 23 2006, 07:54 PM
The fuel pump I think is OK - I can see the fuel flow in the return line and I do hear the pump run for a second when I turn the key. For some reason I think it's the injectors. Any way to check? What else could it be?
John |
Jul 23 2006, 08:04 PM
What engine and what FI?
If it is D-jet, you should be able to hear the injectors click several times each when you open the throttle valve with the ignition on. The Throttle Position Sensor enrichment will pulse the injectors. You could also try a noid light to make sure it flashes (indicating a pulse to an injector). You could pull the injectors out(still connected to the fuel rail and have the other end in a container) to see if they squirt fuel. |
vesnyder |
Jul 23 2006, 08:44 PM
johnman - It is a D-jet, so I will check to see if I hear a clicking when I open the throttle. Can I just put a sensor light between the contacts of the injector to see if it flashes? Thanks
vesnyder |
Jul 23 2006, 09:03 PM
I can really hear the injectors - and feel them clicking as well. There seems to be only one per side that is clicking - normal? I assume that is good? What else? Could it be the fuel pressure?
Bleyseng |
Jul 23 2006, 11:10 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
They click in pairs. Do the test running the injectors one at a time into a glass jar to see the spray or if they are spraying any gas. Pull the coil wire so there is NO SPARK.
bondo |
Jul 23 2006, 11:13 PM
They click in pairs. Do the test running the injectors one at a time into a glass jar to see the spray or if they are spraying any gas. Pull the coil wire so there is NO SPARK. Pull the 12v wire to the coil, NOT the HV wire from the coil to the distributor. I have seen coils arc from their HV post to ground, with that wire disconnected. (It's also hard on the internal insulation of the coil, because if it can't make a spark, the voltage of the secondary spikes really high) |
McMark |
Jul 23 2006, 11:14 PM
Purchase a mechanics stethoscope and place the probe on an injector while a friend turns the motor over. You should be able to hear if the injectors are firing or not. Could be trigger points got unplugged.
Dr Evil |
Jul 23 2006, 11:42 PM
Have you adjusted your fuel pressure?
Stieve |
Jul 23 2006, 11:47 PM
Senior Member Group: Members Posts: 587 Joined: 6-May 06 From: Sacramento Member No.: 5,996 |
Stop! Is you fuel pump in thr front or rear? I relocated mine up front, and fixed a hose leak after sitting for awhile. So it ran but died, problem was a kinked hose under the tank . Let us know. start with things you last touched first. Mine is a 73 withD-ject.
vesnyder |
Jul 24 2006, 07:41 AM
The fuel pump is in the front, and that may be the issue? I have one of those clear fuel filters and it was leaking up a storm? I also may have a kink in the line, and have also had issues with the pump in the past. Will get under there and take a better look - hopefully soon.
tdgray |
Jul 24 2006, 07:48 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Vance. If you get stuck let me know. I am in your neck of the woods.
My time is limited but I can give you a hand. Believe me, I have been there and done that with the fuel situation. You have not mentioned it I think... are you sure you are getting fuel to the rails? |
vesnyder |
Jul 24 2006, 08:53 AM
Todd - Appreciate the offer. Hopefully we can work through it virtually! I can see fuel in the return fuel line, but I am not convinced I have the correct flow and/or pressure to the rails? I need to check the pump and filter to ensure I am getting unrestricted flow - the lines tend to gimp under the tank and I've had pump issues in the past? Will let you know if I find anything interesting!
You can send me an email at vesnyder@hotmail and bypass this thread if you prefer? |
Bleyseng |
Jul 24 2006, 08:58 AM
So you see fuel in the return line? What about the feed line? You could have the lines crossed so no fuel is in the feed line under 30lbs PSI to the fuel rails.
You can just pull an injectors and spray it in a glass jar to check....unplug the 12v power feed to the coil first. |
Lo-Fi Version | Time is now: 11th June 2024 - 08:08 PM |
