Bugpack Oil cooler install, where the heck does this go? |
-JR- |
Jul 24 2006, 11:15 PM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
I don't know if they've packaged the wrong part(s) in my package or what! But how the hell do they expect you to seal up the block adaptor plate without running TWO oil filters?
Posted pictures here.... Anyone seen this? Maybe it's just too late at night. -JR- |
Aaron Cox |
Jul 24 2006, 11:17 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
uh... you have a sandwich adapter and a remote filter mount...
send the remote filter mount back.... all you need is the sandwich plate, oil lines and a cooler... lines go from sandwich plate to cooler and back |
-JR- |
Jul 24 2006, 11:54 PM
uh... you have a sandwich adapter and a remote filter mount... send the remote filter mount back.... all you need is the sandwich plate, oil lines and a cooler... lines go from sandwich plate to cooler and back Thought about that, as there still is room for the filter to fit on under it and still be above the lower cross arm. Thanks! |
URY914 |
Jul 25 2006, 05:52 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,091 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
CoolAirVw |
Jul 25 2006, 06:26 AM
Member Group: Members Posts: 66 Joined: 4-July 06 From: Kansas City Area Missouri Member No.: 6,370 |
Why no pics of cooler? Where ya putting it?
Aaron Cox |
Jul 25 2006, 07:46 AM
yeah... and resize and post your pics in this thread for better response.
link hopping can be tedious |
hmeeder |
Jul 25 2006, 08:18 AM
Dante's Sportscar Group: Members Posts: 352 Joined: 21-November 04 From: San Diego, CA Member No.: 3,154 |
Isn't the sandwich adapter missing its seal? (should go in the groove around the top in picture 214.)
Also, the remote mount is missing the threaded portion that the filter would screw on to. I had clearance problems with engine mount bar when using the sandwich adapter. There are shorter versions of the oil filter that will work, but that means less filter medium. It looks from the diagram that you should have a simple screw on, block off adapter that runs to the remote mount. That's what I use so I can use the correct (larger) filter. My $.02? you got screwed on an incomplete/incorrect kit. return it ASAP-est |
Lo-Fi Version | Time is now: 12th June 2024 - 07:43 AM |
