914-6 and 911/912 Stub axles |
db9146 |
Jul 26 2006, 12:34 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Quick question - Are the stub axles from an early 911/912 and those from a 914-6 the same?
John |
Jul 26 2006, 02:51 PM
NO!
The CV Joints were different, so the flanges are different (splines are the same). |
Cap'n Krusty |
Jul 26 2006, 03:14 PM
Quick question - Are the stub axles from an early 911/912 and those from a 914-6 the same? Depends on your definition of "early". True "early" 900 series cars, 1964-1968, are REALLY different, and use 2 bearings. Later ones differ in CV diameter and configuration, but may fit the splines. The Cap'n |
70Sixter |
Jul 27 2006, 09:59 AM
Member Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
Depends on your definition of "early". True "early" 900 series cars, 1964-1968, are REALLY different, and use 2 bearings. Later ones differ in CV diameter and configuration, but may fit the splines. The Cap'n Cap'n is correct as usual. The "early" lobro halfshafts had two universal joints per side. CV joints replaced them in 69 I think. |
Cap'n Krusty |
Jul 27 2006, 10:43 AM
Depends on your definition of "early". True "early" 900 series cars, 1964-1968, are REALLY different, and use 2 bearings. Later ones differ in CV diameter and configuration, but may fit the splines. The Cap'n Cap'n is correct as usual. The "early" lobro halfshafts had two universal joints per side. CV joints replaced them in 69 I think. Actually, CV jopints appeared in 67, IIRC. Retrofit kits with inner and outer stub axles and a CV joint halfshaft were in the kit. Many cars had them installed one side at a time, so you would see them in the shop with one of each. The pre 1969 outer shafts were about 10" long and had a small number od large ssquare cut splines, much like a VW bug or bus. The Cap'n |
Lo-Fi Version | Time is now: 6th June 2024 - 07:06 AM |
