Koni Red Strut Inserts, 2 Questions |
Allan |
Jul 26 2006, 05:16 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I have 2 sets of red koni's and the part numbers differ. They are all marked 82R-, then the numbers change, i.e., 82R-1943, 82R- 1730, etc. Is the 82R the type designation and the -1943 the serial or lot number?
Also, they are adjustble but do not engage any mechanism when fully depressed and click as they are turned as I was told. There is just an arrow pointing counter clockwise for harder. The shaft will turn 2 1/2 rotations and stop. So I'm guessing full counter clockwise is full hard and full clockwise is full soft. If I rotate them 1 1/4 turns is that medium? What is the best setting for these struts on a /6 with front and rear sway bars? Gracias... |
Cap'n Krusty |
Jul 26 2006, 06:05 PM
82R-xxxx is the Koni part number. If ANY of the 7 digits is different from another unit, then they ARE different parts. Might look pretty much alike, but they're still different. 82R-1943 is a front insert, 911-1975-1982, for Boge struts. 82R-1730 is a front insert for 914/4 and 914/6, all with Boge struts. Koni and Bilstein struts require different inserts. The Cap'n
SLITS |
Jul 26 2006, 06:14 PM
Allan |
So what is the difference other than the vehicle they are designated for?
I have swapped them around and they all fit in either the 914 /4 or 911 struts. Valving, dampening rate? |
SLITS |
Jul 26 2006, 06:18 PM
You answered your own question...read the PDF
Jeroen |
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
koni's for a 911 have different valving than koni's for a 914
Allan |
Jul 26 2006, 06:32 PM
Okay, I read it and understand the differences.
Where would you set the valving on the 911 insert on a 914 used primarily for aggressive street and the occasional a/x? |
Eric_Shea |
Jul 26 2006, 06:54 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Set both full soft. My conversation with Koni suggested that only high speed rebound is different.
Full soft gives you a firm agressive street disposition and allows the suspension to 'react' under autocross demands. |
anthony |
Jul 26 2006, 07:03 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Personally, I wouldn't install two different shocks on my car.
Eric_Shea |
Jul 26 2006, 07:19 PM
(IMG:style_emoticons/default/agree.gif) but... Koni did say they were damn near identical.
Allan |
Jul 26 2006, 07:22 PM
Personally, I wouldn't install two different shocks on my car. Nor would I. I have sets with both numbers. I was just wondering what the difference was. (IMG:style_emoticons/default/wink.gif) |
anthony |
Jul 26 2006, 07:32 PM
Ok, gotcha. I thought you had mis-matched shocks there. I'd use the 914 part number.
SLITS |
Jul 26 2006, 09:47 PM
Personally, I wouldn't install two different shocks on my car. Nor would I. I have sets with both numbers. I was just wondering what the difference was. (IMG:style_emoticons/default/wink.gif) Since you are using the stock torsion bars, I would use the 914 inserts...THE ONES I PUT IN THE STRUTS......then you can pass the elebens to me (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 02:16 PM |
