> running oil lines, Know where I am going to run then but from where?
mikelsr
post Jul 28 2006, 08:27 AM
I am showing my ignorance again. I was looking at the oil tank last night and it occured to me that I don't know the proper place to connect the oil lines going to/from an external cooler. This is on a 2.7L with the original oil tank. I need to install an external oil cooler and I have done some research and found out where people run their lines, where to put the cooler, etc, but I haven't heard any one talk about how you hook up the lines on the engine/oil tank side. Can someone tell me how they should be connected?
If this has been talked about before I apologize but I couldn't find it in the archives.
TIA,
Mike
Replies(1 - 3)
post Jul 28 2006, 10:15 PM
Resident German
Grngoat
post Jul 28 2006, 11:25 PM
Lurker Member
The feed line that goes from the outlet (bottom) of the oil tank to the connection just under the block mounted cooler stays the same. All of this is on the driver's side. Your external cooler will go between the outlet on the passenger side of the block and the oil return in the engine bay just under the tank mounted filter. There are a million ways to route all of that, but that's the basics.
mikelsr
post Jul 29 2006, 07:58 AM
Thanks Avery and SirAndy. Now to gather the parts.
- Lo-Fi Version Time is now: 15th April 2026 - 03:11 PM
