| vesnyder |
Jul 28 2006, 09:53 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
Had this issue before my recent engine pull, but it is back. When coming to a stop and push clutch in the engine just redlines? When it first happened I assume it was the throttle cable sticking, but after replacing it has to be something else? What else could it be? It is fairly random - does not happen every time I stop. The last few times I just shut it down and start it right back up, and away I go! One of these time I am going to do some damage to the motor! Any ideas on what it might be? Something part of the vacuum system or throttle body that could be sticking? Not a safe issue to have! HELP
| Cap'n Krusty |
Jul 28 2006, 09:57 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Classic symptoms of the clutch and throttle cables being intertwined. The Cap'n
| Aaron Cox |
Jul 28 2006, 10:01 AM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
i (IMG:style_emoticons/default/agree.gif)
in the tunnel, your cables are twisted..... push clutch, it also pulls on throttle cable |
| Allan |
Jul 28 2006, 10:05 AM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) Happened to me after "Dad" decided to work on my throttle set-up... (IMG:style_emoticons/default/dry.gif)
| machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
i use a little mirror to look down the tunnel from the front to make sure they are not twisted...
| Demick |
Jul 28 2006, 10:09 AM
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
As others have said, it is very likely the throttle cable (even if you replaced it) because unless specific precautions are taken, it is natural to wrap the throttle cable around the clutch cable.
However, if this is not the case, it can be your deceleration valve. When they go bad, it usually causes very high idle like you describe. To test, just disconnect all lines going to the decel valve and plug them all (plug the disconnected hoses, not the decel valve ports). If the problem goes away, then the decel valve is your problem. Either replace it, or many people just remove it alltogether and leave all of the lines that went to it plugged. It's mostly an emissions device. Demick |
| johnc |
Jul 28 2006, 11:12 AM
Newbie ![]() Group: Members Posts: 49 Joined: 30-January 05 From: Palos Verdes, Ca Member No.: 3,530 Region Association: None |
check the pedal cluster. The throttle cable ball attachment can be moved by the clutch arm when the throttle cable is slack. A fix is to make sure the throttle cable is tight enough! l
| vesnyder |
Jul 28 2006, 12:24 PM
Johnc - I just went and checked my cable and I hope you are right! I worked on that cable for hours in the Spring, and I was sure (at the time) that I had the cables separate! Let's hope I got it this time!
| 914fan |
Jul 28 2006, 01:39 PM
Member ![]() ![]() Group: Members Posts: 118 Joined: 17-January 05 From: Fountain Valley CA Member No.: 3,460 |
I agree. Check that the clutch cable is not pulling the throtle cable AT THE PEDAL END. I dont see how cables twisted would cause a problem. Espically since the cables are in sheeths. But you never know. I have had my clutch cable catch the throtle many times. Check at the pedal cluster in the tunel.
Lo-Fi Version | Time is now: 20th March 2026 - 12:16 AM |
