Turbo Tie-Rod Problems, HEEEEELLLLPPPPP!!! |
Allan |
Jul 28 2006, 04:12 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Finally got my struts in and am trying to do a rough alignment at attach the tie-rods to the steering arm on the strut.
Guess what? The tie-rods won't come down far enough to get the tie-rod end under the steering arm... (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/WTF.gif) Here's a couple of picks. Attached image(s) |
Allan |
Jul 28 2006, 04:13 PM
another
Attached image(s) |
Brad Roberts |
Jul 28 2006, 04:14 PM
Lift the tire (IMG:style_emoticons/default/alfred.gif)
Why did you take those off anyway? You should have installed them with the rest of the assembly. B |
Brad Roberts |
Jul 28 2006, 04:15 PM
Swing the strut out of the way and screw the ends back on.
Dont forget you can move the steering wheel.... B |
Brad Roberts |
Jul 28 2006, 04:16 PM
I have NO idea how you got the boot all the way back like that!! Good job!! It is a pain in the ass...
B |
Allan |
Jul 28 2006, 04:17 PM
Lift the tire (IMG:style_emoticons/default/alfred.gif) Why did you take those off anyway? You should have installed them with the rest of the assembly. B They are new. What will happen the next time I jack the car up and the suspension is at full extension? The rod hits here. Attached image(s) |
Allan |
Jul 28 2006, 04:20 PM
Swing the strut out of the way and screw the ends back on. The problem I'm having is that the tie-rod won't swing down far enough to get the end under the control arm. (IMG:style_emoticons/default/confused24.gif) |
Brian_Boss |
Jul 28 2006, 04:26 PM
Member Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
If you lift the suspension to get it together, make sure it doesn't break/bend something when it goes back to full droop.
I recently did the turbo tie rods on my otherwise stock suspension and don't remember this being a problem. |
Aaron Cox |
Jul 28 2006, 04:34 PM
was on the phone with allan,
he said upward it has 60* of travel, and downward only has about 30 degrees.... i said use the turnbuckle flat on the shaft and rotate the shaft a half turn, now it should pivot 60 down, and 30 deg up |
Allan |
Jul 28 2006, 04:40 PM
i said use the turnbuckle flat on the shaft and rotate the shaft a half turn, now it should pivot 60 down, and 30 deg up Didn't work, It still seems to pivot up farther than it will down. Found the flat spot on the rod. Attached image(s) |
Aaron Cox |
Jul 28 2006, 04:42 PM
then it sounds like you need to get another .5 turns on the rack side, or loosen a half turn...
try this. loosen the inner side a half turn, then button everything up, then tighten it the half turn.... |
Allan |
Jul 28 2006, 04:52 PM
Tried loosening it at the rack.
No luck. It just looks like it's moving farther. I think they may be the wrong ones... (IMG:style_emoticons/default/headbang.gif) |
AZ914 |
Jul 28 2006, 05:10 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
Huh.. I'd put the end on. This sounds stupid and maybe I just can't tell from the pics but is your steering rack/wheel turned all the way to the other side? Maybe jack up the wheel.. ?
Allan |
Jul 28 2006, 05:14 PM
Car is in the air and wheel is straight.
Wrong parts definitely..... (IMG:style_emoticons/default/sad.gif) |
swood |
Jul 28 2006, 05:26 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Just curious...what parts are wrong? Are there different TTR's?
Brad Roberts |
Jul 28 2006, 05:31 PM
Do you have the spacers in place?
Can you call me? B |
Brad Roberts |
Jul 28 2006, 05:43 PM
He has the right parts. He doesnt need the spacers he has in place. He has 911 struts so the spacers are not required.
B |
Brad Roberts |
B |
Allan |
Jul 28 2006, 06:37 PM
(IMG:style_emoticons/default/smilie_pokal.gif) Success!!!!!!!!!!!!!!!!!!!!!!!
Yep, spacers were throwing everything off. Pulled them out and voila, worked like a charm..... Thanks Brad.... |
Brad Roberts |
Jul 28 2006, 06:40 PM
No problem Allan.
Thanks for sharing your "build" with the 914Club (IMG:style_emoticons/default/beerchug.gif) B |
Lo-Fi Version | Time is now: 29th May 2024 - 05:56 AM |
