Can you extend the wires of the LC-1? |
lmcchesney |
Jul 29 2006, 05:18 AM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
OK. I was worried about leaving the controller box, it looks expensive, exposed on the tranny. Can I extend the five wires from the LC-1 sensor, over the tranny,along the side wall of the engine compartment and through the firewall? Are these wires fixed to a measured resistance for calibration or voltage generation like a cylinder head temp sensor?
Larry |
MecGen |
Jul 29 2006, 05:53 AM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hi
Nope, shouldn't be a problem. I lenghthened one Ford and and one Chev (non-914) without any problems. I think there are some companies that sell extensions for the LS1, maybe http://www.painlesswiring.com/ Wherever you deside to mount it, try to keep it dry, the ECMs are sealed, but water always finds a way in (IMG:style_emoticons/default/ar15.gif) Good luck Later (IMG:style_emoticons/default/beerchug.gif) |
gklinger |
Jul 29 2006, 08:07 AM
doh! Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
There's lots of good info over at the Innovate forums, including this:
Oh, are you talking about the cables from the LC-1 to power/ground/analog outs/serial? For those there is no max length (aside from using large enough gauge for 12V and heater GND). There is a max length for the serial cables though. It is 30 feet. The only real length restriction that should not be tampered with is the length between LC-1 and sensor. |
lmcchesney |
Jul 29 2006, 09:04 AM
Yes, from the O2 sensor in the tail pipe to the black box its cable connects to. Same or larger gauge wire.
I just placed the question on the LC-1 forum as well. The sensor is in the exhaust pipe and I want to extend the wires so the controller, the rectangular box the sensor cable pluggs into, in the relay box on the left side of the engine compartment and run the wires, which are plenty long enough, through the firewall and into the cockpit. Thanks, Larry |
lmcchesney |
Jul 29 2006, 09:21 AM
Reading the LC-1 forum, I understand that you can only extend the wires from the O2 sensor to the controller box by about 2 ft. Is this correct?
Larry |
lmcchesney |
Jul 29 2006, 11:12 AM
Bump
Lo-Fi Version | Time is now: 8th June 2024 - 03:07 PM |
