black wire, purple stripe, from coil, what's it for? |
HeloMech |
Jul 29 2006, 12:18 PM
Go Ahead, Get Pistoph! Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California |
It's on the same side as the green wire from the condensor.
Black with purble stripe. comes out of a twin wire wrap. What's it do? |
Brad Roberts |
Jul 29 2006, 12:19 PM
Tach wire (IMG:style_emoticons/default/biggrin.gif)
You need a Haynes manual badly (IMG:style_emoticons/default/beerchug.gif) B |
HeloMech |
Jul 29 2006, 12:20 PM
Tach wire (IMG:style_emoticons/default/biggrin.gif) You need a Haynes manual badly (IMG:style_emoticons/default/beerchug.gif) B I have one but I don't see where it lists color codes... just a bunch of black and white drawings. |
Brad Roberts |
Jul 29 2006, 12:23 PM
Each page you see with the "graphics" has a page associated with it that tells you what each component is and what the colors are.
B |
So.Cal.914 |
Jul 29 2006, 12:24 PM
Look real close there are breaks it the line and the colors are abbrivated.
SirAndy |
Jul 29 2006, 12:26 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Look real close there are breaks it the line and the colors are abbrivated. (IMG:style_emoticons/default/agree.gif) it's all there, you're just not looking hard enough ... (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/biggrin.gif) Andy |
HeloMech |
Jul 29 2006, 12:30 PM
Look real close there are breaks it the line and the colors are abbrivated. (IMG:style_emoticons/default/agree.gif) it's all there, you're just not looking hard enough ... (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/biggrin.gif) Andy OK, I see it... looks like it goes into a regulator, spot 5, then spot 5 comes out as a green/red... then off to the tach. I think I just need a poster size color chart for the garage wall. Or better yet, an electronic version that hangs there. I touch the wire in question and it lights up everything about that wire, it's path and component. Yes, that's what I need. thanks guys |
Brad Roberts |
Jul 29 2006, 12:31 PM
Brad Roberts |
Jul 29 2006, 12:35 PM
Print the above off and these two:
Attached thumbnail(s) |
Brad Roberts |
Jul 29 2006, 12:36 PM
Can you get me a ride in a Helicopter?
Or a beer the next time I'm in OC ?? LOL B |
SirAndy |
Jul 29 2006, 12:55 PM
OK, I see it... looks like it goes into a regulator, spot 5, then spot 5 comes out as a green/red... then off to the tach. NOOOOOOOOOOOOOOOOOOOOOOOOOO you can't simply assume that PIN 5 on the rear plug is connected to PIN 5 on the forward plug! you gotta trace the wire through the relay board! PIN 5 on the rear connector (black/purple tach wire) goes to PIN 7 on the forward connector (also black/purple) which goes to PIN 1 on the tach ... (IMG:style_emoticons/default/slap.gif) Andy |
So.Cal.914 |
Jul 29 2006, 01:05 PM
When the diagram gets real busy I use a straight edge and lay it along the wire
I am tracing down. Helps to keep from losing it in the traffic. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 11:22 AM |
