> baa baaa baa bababababaaaa baaaa, what's it mean?
HeloMech
post Jul 29 2006, 12:24 PM
Go Ahead, Get Pistoph!
lol.
ok, this morning I set the dwell and timing. I drove the car. seems to do ok. If I hold the rpm's up, the car does that nice smooth running sound... then it's interrupted with the ba ba bababa baba baba.... I dunno if it's missing, sucking air, fuel issues or what...
Joe... this car is SOOOOO gonna end up stuck in your driveway! lol.
also, I pulled the wire from the throttle switch, was going to try that again now that it's timed... then the car wouldn't start. lol. Grrrr....
Replies(1 - 7)
So.Cal.914
post Jul 29 2006, 12:31 PM
"...And it has a front trunk too."
Oh boy, take your pick. Start with the easy(cheap) stuff Look for a shorting plug
wire. When is the last time the condenser was changed? Check valve clearance,
vacuum leaks and fouled plugs.
JoeSharp
post Jul 29 2006, 12:32 PM
In Irvine, Ca. May 15-18
You have AAA and it is less than 5 miles to my house and that should put within the cars 8.7 mile self imposied running limit. You know I'm going to tell you to straighten out your vacume lines.
:PERMAGRIN: Joe
HeloMech
post Jul 29 2006, 01:13 PM
QUOTE(So.Cal.914 @ Jul 29 2006, 11:31 AM) *
I just replaced the plugs, wires, cap, rotor, points, condensor, coil, battery. This morning I set the timing.. which was at about 27 at IDLE.. not at the 3500rpms like in the book. I haven't checked the valves as of yet. I'm going to pull the plugs again and see how they've faired since the car has been running. vacuum hoses have all been changed. There are some that go to the air cleaner that are a little weird because of this funky cold air intake thing on the car from the PO.
pete-stevers
post Jul 29 2006, 01:15 PM
saved from fire!
i thought this was a thread stated to entice miles back
HeloMech
post Jul 29 2006, 01:52 PM
QUOTE(pete-stevers @ Jul 29 2006, 12:15 PM) *
someone fancy the occasional sheep? (IMG:style_emoticons/default/sheeplove.gif)
lol, as I click that emoticon.. it actually says miles...
You guys are just WRONG! lol
fiid
post Jul 29 2006, 04:33 PM
Turbo Megasquirted Subaru Member
I don't know - but:
laa laa laa laa lalala laaa
is from the chrorus of Hey Jude by the Beatles....
JoeSharp
post Jul 29 2006, 04:42 PM
Dude, mine was worse than that.
Bam Ba Bam bam ba bam bam.
:PERMAGRIN: Joe
- Lo-Fi Version Time is now: 19th July 2025 - 06:01 AM
