| propricer |
Jul 29 2006, 01:46 PM
Member ![]() ![]() Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
Considering a project which would fit a 928 automatic transmission into a 914 V8 conversion.
Looking for comments from informed clubbers, especially if there's someone out there that has done one. Appears R&P does NOT have to be flipped. Appears the starter will have to be installed from the engine side. Will require a custom adapter plate and, probably, a custom flywheel. Not sure of the fitment ( length, width, etc. ) and the angle as a result of the CV exit points. Any comments / advice would be appreciated ... |
| Brad Roberts |
Jul 29 2006, 01:51 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Save yourself a BUNCH of hassle and use the Corvette rear tranny solution.
The issue is: the axle location. Our gearboxes have the gear cluster BEHIND the axle line. They have it in FRONT of the axle line. You would have to extend the car 2 feet. KEP sells and adapter for an Audi5000 Automatic that uses Ford C4 auto tranny parts (same size) It will handle a decent SBC 350 B |
| Brando |
Jul 29 2006, 02:17 PM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Besides, as expensive a Mercedez Benz trans is to repair, why create a lot more work for yourself? |
| Brad Roberts |
Jul 29 2006, 02:27 PM
Here is an Interesting thought:
996TT ChickTronic They will handle an easy 550hp and 500lb ft or torque. Just dont use the front drive portion.. it is also a Mercedes tranny. Damn.. not sure if you can flip the diff or not... Here are some shots: (IMG:http://www.mindovermotorsports.com/pics/adamr/images/DSC03169.jpg) (IMG:http://www.mindovermotorsports.com/pics/adamr/images/DSC03179.jpg) |
| Joe Ricard |
Jul 29 2006, 02:29 PM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
928 trans is 150 pounds for a manual and well over 200 for an auto.
the input to the trans is via and impeller shaft. you would have to figure out bell housing. one off piece. |
| plymouth37 |
Jul 29 2006, 07:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest
how about a subaru 2wd auto box?
Lo-Fi Version | Time is now: 15th September 2026 - 05:40 AM |
