oil pump adventure, changing pump without dropping engine |
72914S |
Jul 31 2006, 02:12 PM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
Lazy me decided to fix my oil pump leak with out droping the engine. Found both gaskets were broken(Melling pump) Removed engine fan shroud took off belt then the fan. Unbolted the fan housing moved it up and out of the way,not very far.Then I unbolted the pump;forgot to drain oil!After cleaning mess on the floor I pulled the pump from between the engine mounts(Tight fit).I work at a marina the techs here turned me on to a gasket seal they use to seal outboard cases,it works on all metals,fills gaps upto .050 and doesn`t setup until it`s tighten down between the two pieces.It looked like strawberry jelly when it squished out. Put the fan housing back on(5 hours later)Tonight I will fire it up before putting the fan back on(after putting oil in and only for minute to see if it leaks)Insert praying smilie)
DNHunt |
Jul 31 2006, 02:49 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Sounds like Loctite 518. It's anaerobic. As long as air can get to it, it won't set. Good stuff, smells bad.
Dave |
72914S |
Jul 31 2006, 03:51 PM
This is a Yamaha product but you are right same stuff.Hope it holds!
72914S |
Aug 1 2006, 05:42 AM
No leaks last night so I put all the tin back on.Tonight we take it out for a SPIRTED drive.HEY Joe now maybe you can follow me up to Dothan.ha.ha.ha
Brando |
Aug 1 2006, 06:38 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Yamabond. It's all the rave!
Minus the glowsticks. |
ptravnic |
Aug 1 2006, 07:03 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
Do I understand correctly that this "Yamabond" stuff is the cure for oil leaks? I'll be replacing my crankshaft seal, installing new heads, replacing oil cooler and seals, and a few other doo hickeys while in there. Should I use this Yamabond stuff as a sealant? Kinda like the way I used Permatex to seal up the case?
Brando |
Aug 1 2006, 07:43 PM
I was just saying that (probably should have used a smiley).
It's a very good anærobic sealing agent. Loctite is also another. It comes down to what you think will last, what will hold out the longest. My experience with yamabond is that it works, and for quite some time. |
72914S |
Aug 1 2006, 08:22 PM
I`m doing a test right now I shall keep you informed.
DNHunt |
Aug 2 2006, 08:10 AM
I haven't tried Yamabond so I can't speak to it. I really like the Loctite product. I used it for the oil pump and for plugs along with the sealing rings. One thing I would say, if what you are sealing will take a while to torque down this isn't the right stuff there. It sets fairly quickly once air is cut off. For instance you couldn't seal case halves although it is what I used under the through bolts and nuts. It's also a bitch to clean when it is set.
Dave |
72914S |
Aug 2 2006, 10:37 AM
Went for ride last night (car wash under side). Flogged for 30 minutes,but not in my neighbor hood ha..ha.ha.Parked it saw one spot of oil;must have been missed at the car wash.No oil spot this morning in garage. (IMG:style_emoticons/default/boldblue.gif)
Lo-Fi Version | Time is now: 11th June 2024 - 10:52 PM |
