BAR SWAP and Springs? |
ffranktly |
Aug 1 2006, 10:06 AM
Member Group: Members Posts: 112 Joined: 14-August 05 From: alameda, ca Member No.: 4,586 |
i have a 22mm Weltmeister Sway Bar and 250# springs, on a 75 2.0, and if anyone would like to swap, i need a 19mm Bar and #140 springs. thanks!... frank (IMG:style_emoticons/default/smash.gif)
and if anyone needs my Bar and Springs when i do the changeover, i can sell you mine and have them sent. (IMG:style_emoticons/default/beerchug.gif) |
Mueller |
Aug 1 2006, 11:01 AM
I can do the front bar (let me double check the dia, but I'm pretty darn sure it's the smaller of the 2)....bar only has about 100 miles on it (60 miles of that on the back of a AAA tow truck (IMG:style_emoticons/default/headbang.gif) )
maf914 |
Aug 1 2006, 11:20 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I don't want to sabotage Mike's offer, but...
Is a 22mm Wetmeister bar too big to run with 140# springs, assuming stock T-bars and equal size tires front and rear? Is there enough adjustment to run it soft enough? |
Aaron Cox |
Aug 1 2006, 12:47 PM
set on full soft it should be fine.....
ffranktly |
Aug 2 2006, 10:29 AM
thanks guys, and ill wait to hear from you Mueller! does anyone need the 22mm Weltmeister?
Heeltoe914 |
Aug 2 2006, 10:32 AM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Is this a rear bar?
maf914 |
Aug 2 2006, 10:36 AM
I assume it's a front sway bar. Weltmeister makes 19mm and 22mm sway bars for the front and a 16mm bar for the rear for 914's.
ffranktly |
Aug 2 2006, 12:16 PM
i haven't had the car up on a hoist and i just bought the car from joseph mills, but going by what joseph says, it is a rear 22m Weltmeister sway bar
ffranktly |
Aug 2 2006, 12:20 PM
OOPs... my bad,, you are right, i read the specs again... it is the front sway bar (IMG:style_emoticons/default/icon8.gif)
Mueller |
Aug 3 2006, 10:19 PM
I just checked, my bar is a 19mm Welt, I won't be able to remove until this weekend.....
Lo-Fi Version | Time is now: 31st May 2024 - 07:36 PM |
