Cheap 914 owners, This says it all |
DNHunt |
Aug 5 2006, 11:37 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
I didn't want to replace my key so, I started thinking how I could get the plastic part to stick to the actual key. Small wire ties were the answer. It should last as long as I need it.
Dave Attached image(s) |
dekman |
Aug 5 2006, 11:49 AM
Member Group: Members Posts: 458 Joined: 12-December 04 From: Ojai,CA Member No.: 3,274 Region Association: None |
INGENIOUS /adj : marked by special aptitude, inventing, original, cleverness in conception, resourcefulness. (IMG:style_emoticons/default/clap56.gif)
BenT |
realty check casher Group: Members Posts: 103 Joined: 21-June 06 From: San Francisco Member No.: 6,273 Region Association: None |
I didn't want to replace my key so, I started thinking how I could get the plastic part to stick to the actual key. Small wire ties were the answer. It should last as long as I need it. Dave Reminds me of the 75 914 I had that someone converted to 914-6. I guess money ran out for new transmission mounts because they used a chain (the kind you get from the local hardware store) and a padlock to secure the transaxle. BenT |
messix |
Aug 5 2006, 11:51 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
jeez dave, don't you have so kinda epoxy that you glue stuff together with laying around? maybe some efferdent.
sixnotfour |
Aug 5 2006, 11:55 AM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE jeez dave, don't you have so kinda epoxy that you glue stuff together with laying around? maybe some efferdent. at least he didnt use bailing wire, now if you had used saftey wire and done it proper youd be held high regard. |
messix |
Aug 5 2006, 11:58 AM
GWN7 |
Aug 5 2006, 12:09 PM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
highways |
Aug 5 2006, 12:45 PM
Senior Member Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 |
All you need now is a miniture jackstand keyring (IMG:style_emoticons/default/thumb3d.gif)
morph |
Aug 5 2006, 12:53 PM
quality parts builder Group: Members Posts: 1,828 Joined: 25-November 03 From: oregon coast Member No.: 1,389 Region Association: Pacific Northwest |
q tip and some alcohol clean it up real good. Find some cheap epoxy done. but ties? i thought i was a cheapo (IMG:style_emoticons/default/laugh.gif)
james |
jonwatts |
Aug 5 2006, 01:36 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
Dave aren't you a dentist? Where's the stainless steel wire you use for braces?
swood |
Aug 5 2006, 02:09 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
JPB |
Aug 5 2006, 02:45 PM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Some do not SEE the GREATNESS of this MAN's ENGINUITY!! Purist Minimalist have unanimously crowner this idea worthy of one gold star, two Swedesh Chics and an all you can eat Swedish seafood buffet of your choice.
(IMG:style_emoticons/default/beer.gif) To be large one must think large! (IMG:style_emoticons/default/smilie_pokal.gif) Congats brother and show your GEATNESS with pride! |
DNHunt |
Aug 5 2006, 07:37 PM
This is the same key Dino complained about at WCC in the AX. It separated and all the keys on the key ring flew around while he was driving. Some kind of Murphy's law applied to racing. What can break will break. No more Dino. I applied good old 20th century technology to it (don't tell hom it is the 21st century now).
I'm really quite pleased with myself. It is certainly better engineered than my scoop under the car to provide air to the oil cooler in front of cylinder #2. It is also better than my rally top on which I can carry 2 AX tires (ask JP about that). It is however far short of the crankfire ignition set up on my 914. Some things work some don't. Dave |
dinomium |
Aug 5 2006, 07:48 PM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
Dave, you may have missed your true calling! Too funny, brother!
Toast |
Aug 5 2006, 10:04 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
(IMG:style_emoticons/default/lol2.gif)
You should have used red ones (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 07:54 AM |
