Rear Bushing Problem, Spins on the shaft... |
yeahmag |
Aug 5 2006, 09:06 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I installed my rear bushings based off the Eric's thread:
http://www.914world.com/bbs2/index.php?showtopic=12139 ...and mine are rotating around the shaft. Should I go with it and remove the arm again and lube the shaft or should I hone the arm in hopes it will move there? It moves really easy on the shaft with no grease, so I feel like I should remove the shaft, grease it, and go with the flow? Ideas? Thanks. -Aaron |
MecGen |
Aug 5 2006, 09:21 PM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hi Aaron
Yeh I would take it apart and grease the shaft. Probably when everything is pressed together it grips the shaft and turns in the arm insted, if I understood properly.... Later (IMG:style_emoticons/default/beerchug.gif) |
John |
Aug 5 2006, 09:40 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
The shaft that runs through the rear trailing arm is meant to stay stationary. The shaft has serrartions on the ends to help it bite into the inner ear and the outer cup.
The bushing is meant to stay fixed in the arm. The arm and bushing are meant to rotate as a pair around the shaft. I hope that this is what is happening for you. I saw a thread that shows an incorrect installation (they had grooved the OUTSIDE of the bushing hoping that the bushing would rotate inside the arm). This is incorrect. If a grease groove is made, it should be on the inside of the bushing so that grease can get between the bushing and the shaft. just my $0.02 |
Aaron Cox |
Aug 5 2006, 10:13 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
aaron,
grease grooves rock. i have the dremel tool, and the magic weltsheister gorilla jizz lube they reccomend. no squeaks on mine.... grooves allow you to pack the shit out of em with grease. |
yeahmag |
Aug 6 2006, 02:05 AM
It is gripping the arm (even though it's grooved and lubed) and rotating on the shaft. I agree that it seems logical to rotate on the shaft due to surface area and torque... I'll take it back apart and lube the shaft (seeing as it's rotating there anyway).
Thanks. -Aaron |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:10 PM |
