engine project pix, ... break for lunch... |
type47 |
Aug 8 2006, 10:27 AM
made some progress on the project engine. be kind with your comments, i'm a novice mechanic and learning. this is supposed to go into the 914 in my avatar and the plan was to get it in this summer before labor day. want to drive it to the east coast ramble (plug) so johnb can drive my other 914. (shameless retraction of offer to him (IMG:style_emoticons/default/rolleyes.gif) ). the specs are stock d-jet, euro pistons. it's been fun so far.....
Attached image(s) |
type47 |
Aug 8 2006, 10:28 AM
2 more
Attached image(s) |
TravisNeff |
Aug 8 2006, 10:41 AM
Nice touch with the fuel hard lines at the front of the engine.
Aaron Cox |
Aug 8 2006, 10:57 AM
you dont reaaallly need the squirrel cage fan cover tho (IMG:style_emoticons/default/smile.gif)
Get a real coil too! (IMG:style_emoticons/default/tongue.gif) looks awesome!! |
type47 |
Aug 8 2006, 10:58 AM
got the hard line idea from norustscott...
yea, the fan cover was a left over from vw bus parts. thought i'd put it on for jollies. won't really be able to see it anyway. although, the owner of my old car dropped the oil fill cover into the fan area and caused the need for a complete rebuild..... |
maf914 |
Aug 8 2006, 11:51 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I have wondered if the bus fan screen restricts air flow significantly or if the restriction is negligible. I have one in my parts stash and have considered using it. I find small leaves and pine needles in my engine compartment and wonder if any have made it to the sylinders or oil cooler?
JmuRiz |
Aug 8 2006, 01:19 PM
914 Guru Group: Members Posts: 5,432 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Looks good Jim, put a nicer looking coil, or at least clean that one up (IMG:style_emoticons/default/biggrin.gif)
racerx9146 |
Aug 8 2006, 01:42 PM
good design never goes out of date.. Group: Members Posts: 174 Joined: 1-January 04 From: Sacramento, CA Member No.: 1,483 Region Association: Northern California |
looks great! It always bugged me that I could never get the aluminium fan shroud clean. Maybe paint a dull silver?
G e o r g e |
Aug 8 2006, 01:52 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
did you replace the rubber grommets thru the tin? if so where did you get them? (IMG:style_emoticons/default/beerchug.gif)
maf914 |
Aug 8 2006, 02:00 PM
You can get most of them through a VW parts counter. Most of the T4 parts, including grommets, are VW. I did this at the local VW dealer. It helps to have access to the the PET CD so you can record part numbers.
G e o r g e |
Aug 8 2006, 02:04 PM
You can get most of them through a VW parts counter. Most of the T4 parts, including grommets, are VW. I did this at the local VW dealer. It helps to have access to the the PET CD so you can record part numbers. thanks for the info (IMG:style_emoticons/default/beerchug.gif) |
DrifterJay |
Aug 8 2006, 06:38 PM
I break stuff... Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None |
You can make the fan shroud nice and clean if you have access to a sand blaster
type47 |
Aug 8 2006, 07:26 PM
did you replace the rubber grommets thru the tin? if so where did you get them? (IMG:style_emoticons/default/beerchug.gif) have them on order from busdepot.com. have yet to arrive so i'm wondering if they are still available. i have a few from old parts that i salvaged. can't exactly get the part numbers from PET to jive with locations. looking back at the pix; the big stain on the left is the PB blaster i had to use to get the screw out to mount the clip for the tube. also embarrased that the alt pulley is so rusted looking. and Nathan, the coil was cleaned (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 02:25 AM |
