Oh No! I hope it's not... Clutch squeaky, Just got home... major squeaky when push in clutch |
tdgray |
Aug 9 2006, 03:59 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Drove the teener to work today. Nice cool morning great drive.
Picked up my son and headed home. Pulled in the garage and shut the car off. Release the clutch and hear a very noisy squeak. Push it in and out a couple more times... same thing. Was going to get under the car but it is rather warm under there so I thought I would let it cool off. Is this a sign of clutch tube failure???? It has always had what I would call a stiff clutch. I think this normal? I mean it is not like you have to jam it in with all your might but it is certainly not as easy as my subby. What do you think? Are there places it needs lubed? I hope it is not the clutch tube. Please please please don't let it be the tube. (IMG:style_emoticons/default/headbang.gif) |
jr91472 |
Aug 9 2006, 05:16 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
First place I would look is the pedal assembly. Think about new bushings. I replaced mine only to find that the source of the noise was the actual spring on the pedal. Just old and worn out I guess. I hit it with WD40 every month or so until I have a chance to pull the pedal assy (again).
(IMG:style_emoticons/default/beer.gif) Drove the teener to work today. Nice cool morning great drive. Picked up my son and headed home. Pulled in the garage and shut the car off. Release the clutch and hear a very noisy squeak. Push it in and out a couple more times... same thing. Was going to get under the car but it is rather warm under there so I thought I would let it cool off. Is this a sign of clutch tube failure???? It has always had what I would call a stiff clutch. I think this normal? I mean it is not like you have to jam it in with all your might but it is certainly not as easy as my subby. What do you think? Are there places it needs lubed? I hope it is not the clutch tube. Please please please don't let it be the tube. (IMG:style_emoticons/default/headbang.gif) |
Dr. Roger |
Aug 9 2006, 05:37 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
yep, i was thinking pedal assembly also.
is the squeaking coming from the front or the rear area? i use tri-flow. =-) |
Tobra |
Aug 9 2006, 05:41 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
I am partial to Phil's tenacious oil, look for it in a bicycle shop. Nice for cables and what not, high viscosity.
Dr. Roger |
Aug 9 2006, 05:50 PM
Bar and Chain oil for use with chainsaws hangs on very well also.
tdgray |
Aug 10 2006, 06:33 AM
Nope... pedal assembly was rebuilt from Eric Shea.
Sound is definitley coming from the rear / mid of the car. I did not have a chance to look at it last night. Will try to do tonight. Do you have to lube the cable itself or the pulley or anything down there??? |
Lo-Fi Version | Time is now: 9th June 2024 - 10:48 PM |
