How do I remove the switches on the dash? |
HeavyHeavy |
Aug 10 2006, 09:25 AM
Member Group: Members Posts: 62 Joined: 7-June 06 From: Albuquerque Member No.: 6,177 |
Hello.
I want to remove the metal dash trim plates from my dash. You know the ones that are covered with the basket weave vinyl. It looks like I'll need to remove the switches for the lights and windshield wipers and the cigarette lighter. Can someone tell me what I'll need to do to remove those? Thanks |
Cap'n Krusty |
Aug 10 2006, 09:31 AM
Unscrew the bezels. While possible with thin profile curved needle nose pliers, a pin wrench is made for the purpose. The Cap'n
TINCAN914 |
Aug 10 2006, 09:32 AM
Summer's Commin... Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains |
Unscrew the knobs. Once off, there is a washer looking plate with two small grooves towards the center hole. If you have a set of needle nose pliers, put those tips in those grooves, and turn counter clockwise, the center is threaded for the switch. keep turning and the washer will come off. (IMG:style_emoticons/default/smile.gif)
HeavyHeavy |
Aug 10 2006, 09:44 AM
Thanks. I'll give it a try when I get home.
grasshopper |
Aug 10 2006, 10:37 AM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
you can also use a penny to unscrew the retaining ring. Easier, and less chance of scratching the ring.
HeavyHeavy |
Aug 10 2006, 10:51 AM
lapuwali |
Aug 10 2006, 10:58 AM
On some of the switches, the shaft is sunken below the retaining ring when you unscrew the knob. On other switches, it protrudes. You could use a penny on the sunken switches, but not on the others. Scratching the retaining ring is pretty easy. It's also easy to cross-thread them, so go slow.
Unscrewing the knob sometimes takes what seems to be excessive force, but they do unscrew. |
grasshopper |
Aug 10 2006, 11:02 AM
(IMG:style_emoticons/default/agree.gif) when reinstalling them go SLOW..... I have cross-threaded 3 or 4 now...
John |
Aug 10 2006, 11:32 AM
In place of a pin wrench, I have used a washer with a slot cut in one side so that it can be placed over the headlight switch shaft. It works like a charm. It took only a minute or so to make my home-brewed tool. I want to say a 1/2" flat washer, but that may be too thick to fit the slot.
STL914 |
Aug 10 2006, 01:46 PM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
I've used a snap ring pliers with good results when removing the switches from my parts cars.
flesburg |
Aug 10 2006, 05:56 PM
Senior Member Group: Members Posts: 506 Joined: 22-November 04 From: Pontiac, IL Member No.: 3,162 |
The cigarette lighter is held in differently. It has a circlip around it that holds it in place. You will have to crawl under the dash or use a mirror to see it. Disconnect the wires first and push the housing toward the rear of the car until you get the circlip loose, and you may have to push it out all of the way while wiggling on the circlip, but it will come out. To reinstall, put the housing in the hole, slide on the circlip and push it on the housing until it is snug and then reattach the wiring.
terrymason |
Aug 10 2006, 06:27 PM
Member Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 |
wanna sell that wiper switch?
HeavyHeavy |
Aug 11 2006, 10:19 AM
Thanks for the info.
I didn't see the one about the cigarette lighter until today, but I figured it out last night. I just put some curved needle nose behind the lip on the front of the cigarette lighter and pried it forward. Luckily for me that lip was strong enough to pull forward without bending. |
HeavyHeavy |
Aug 11 2006, 10:36 AM
Lavanaut |
Aug 2 2007, 07:51 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
Unscrew the knobs. Once off, there is a washer looking plate with two small grooves towards the center hole. I just want to be sure here ~ the knobs themselves (headlights, hazards, fogs) unscrew? I tried with a fair amount of force and they didn't budge. Does it matter if they're pulled out or not? I'm afriad I'm going to break it. (IMG:style_emoticons/default/unsure.gif) I must not fear, for fear is the mind killer. |
SirAndy |
Aug 2 2007, 08:37 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Unscrew the knobs. Once off, there is a washer looking plate with two small grooves towards the center hole. I just want to be sure here ~ the knobs themselves (headlights, hazards, fogs) unscrew? yes, they unscrew out of the switch .... (IMG:style_emoticons/default/bye1.gif) Andy |
Lavanaut |
Sep 25 2007, 12:14 PM
Can anyone suggest any tips/tricks to prevent the housings for these knobs, that sit behind the dash face, from falling and becoming unreachable when you remove the knobs themselves? I can't see a way to get at some of them at all from behind.
Also, the cigarette lighter ~ once removed, how does one go about getting it back through the circular 'clip' that holds it in place on the inside of the dash? (IMG:style_emoticons/default/confused24.gif) Thanks in advance |
So.Cal.914 |
Sep 25 2007, 12:30 PM
Unscrew the knobs. Once off, there is a washer looking plate with two small grooves towards the center hole. I just want to be sure here ~ the knobs themselves (headlights, hazards, fogs) unscrew? I tried with a fair amount of force and they didn't budge. Does it matter if they're pulled out or not? I'm afriad I'm going to break it. (IMG:style_emoticons/default/unsure.gif) I must not fear, for fear is the mind killer. Yes, Muadib, they do unscrew counter clockwise. Use some force...Oooop's wrong book. QUOTE Can anyone suggest any tips/tricks to prevent the housings for these knobs, that sit behind the dash face, from falling and becoming unreachable when you remove the knobs themselves? I can't see a way to get at some of them at all from behind. You eather have A/C or you have sasquatch hands, eather way the wiring loom usually held mine in place. |
TINCAN914 |
Sep 25 2007, 01:20 PM
[/quote] (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 08:21 AM |
