Type 1 Liquid Cooled Heads, For aircraft engines |
Brian Mifsud |
Aug 11 2006, 12:53 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
I found this site which features newly engineered liquid cooled Type 1 Cylinder Heads for Aircraft Applications. I don't know how they are different from the WasserBoxer design, but most likely, they beefed up the weaknesses in that model. With loads of machining, I'm guessing they could be used on the Type IV?
(IMG:http://www.greatplainsas.com/llceng1.jpeg) Great Plains Aircraft |
Brando |
Aug 11 2006, 01:09 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Anything can be done with enough money... But the question is, why? AFAIK the Type 4 gets some of it's advantage over the Type 1 due to head design. Why not highly modifiy some Wasserboxer heads for that cost?
Jake Raby |
Aug 11 2006, 01:10 PM
Just buy a wasser or suby and be done with it if you want a radiator...
watercooling our heads just creates a bastard engine. |
Brian Mifsud |
Aug 11 2006, 01:14 PM
Anything can be done with enough money... But the question is, why? AFAIK the Type 4 gets some of it's advantage over the Type 1 due to head design. Why not highly modifiy some Wasserboxer heads for that cost? ...........or study this design for someone who is developing a liquid cooled TYPE IV engine and has no problem with the "bastardization"..... some of us have a creative inventive streak that cannot be subdued.. no matter how "expensive"..... |
Rouser |
Aug 11 2006, 01:59 PM
Anti-Post Whore Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 |
... or study this design for someone who is developing a liquid cooled TYPE IV engine and has no problem with the "bastardization" ... I thought that the "liquid-cooled T-IV" issue was resolved with the aforementioned Subi conversion? Can't see the reasoning (i.e. need), even IF you overlook the $$$ involved in R&D; ground already covered. |
Cap'n Krusty |
Aug 11 2006, 02:04 PM
Anything can be done with enough money... But the question is, why? AFAIK the Type 4 gets some of it's advantage over the Type 1 due to head design. Why not highly modifiy some Wasserboxer heads for that cost? Wasserboxer heads ARE T1 heads, so why bother with that, either? The Cap'n |
Brando |
Aug 11 2006, 02:55 PM
Thought wasserboxer heads were watercooled type 4 heads. D'oh.
Brian Mifsud |
Aug 11 2006, 03:19 PM
quote]
I thought that the "liquid-cooled T-IV" issue was resolved with the aforementioned Subi conversion? Can't see the reasoning (i.e. need), even IF you overlook the $$$ involved in R&D; ground already covered. [/quote] Ground covered only as you see it.. look further....... A watercooled TYPE IV head would be a very easy bolt on. Much much easier than all the work in an engine conversion to Subaru. Liquid Cooling system could live in the engine compartment so no butchering the 914 body. Allows serious turbo charging for much fun and excitement. Some of us have already begun to learn how to do castings and built our own aluminum foundries for not much money... who needs to do "research".. superior combustion chambers on pushrod engines already exist..just copy and paste...... |
Rouser |
Aug 11 2006, 03:49 PM
QUOTE A watercooled TYPE IV head would be a very easy bolt on. After you modify the cooling tin (cylinders are still air-cooled), FI system (heads are larger, adding engine width), and everything else for an engine bay radiator system. QUOTE Much much easier than all the work in an engine conversion to Subaru. Not if you're comparing $$$-to-HP; 914 owners tend to be CSOB's. QUOTE Liquid Cooling system could live in the engine compartment so no butchering the 914 body. Yes, that ought to add to the ease of maintenance already encountered by most 914 owners, ESPECIALLY stock FI-equipped cars. QUOTE Allows serious turbo charging for much fun and excitement. Again, talk to 914WRX for that application, or Jake Raby for pure T-IV. In either case, insert "CSOB" here. QUOTE Some of us have already begun to learn how to do castings and built our own aluminum foundries for not much money... And some have abandoned the 914-4 crowd for much the the same reasons ... not enough traffic. QUOTE who needs to do "research".. superior combustion chambers on pushrod engines already exist..just copy and paste...... ... on "watercooled" pushrod engines, which doesn't always translate to T-IV's. I'm not knocking the idea, it's just that the market (and desire/enthusiasm/$$$) isn't there to recoop the investment; and that's always the bottom line. |
Jake Raby |
Aug 11 2006, 03:50 PM
QUOTE superior combustion chambers on pushrod engines already exist..just copy and paste If it were only that easy. The day that watercooled Type 4 engines are common I'll go back to working on turbines. |
Lo-Fi Version | Time is now: 28th May 2024 - 06:45 PM |
