WE HAVE IGNITION!, It actually runs... |
Allan |
Aug 13 2006, 12:33 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Well I finally got a chance to get out in the garage and putz with the MSD/Pertronix set-up and after about an hour of wiring and checking and double checking and triple checking it runs!!!!!!!!!!!
I haven't got the tach hooked up and I know the timing is probably way off but it starts, idles and revs pretty good. Thanks for all the input on getting this thing (actually me) figured out. Now I gotta go figure out the tach and get it timed. Then it's (IMG:style_emoticons/default/burnout.gif) |
JPB |
Aug 13 2006, 01:12 PM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Aaron Cox |
Aug 13 2006, 01:31 PM
a 74+ 911 tach *Should* work, as it has the xener diode (sp?) that the earlier ones dont have.....
Brando |
Aug 13 2006, 01:51 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Hey Allan, wasn't it running before? (IMG:style_emoticons/default/biggrin.gif) (before you fiddled with it)
Just joshin' ya. Glad to hear it works and runs great. Pretty soon you'll be smokin' tiars at your next local event. |
wbergtho |
Aug 13 2006, 05:03 PM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
You are a go for Translunar injection! Good job!
J P Stein |
Aug 13 2006, 07:53 PM
I have a 911 tach dated 1971 & it works without an adaptor.
Black/purple wire. |
Allan |
Aug 13 2006, 08:47 PM
I have a 911 tach dated 1971 & it works without an adaptor. Black/purple wire. JP, unfortunately I have a car that has the wiring hacked together so color is not something I can use as a reference. I believe I have the tach wire isolated but I'm getting different recommendations as to whether or not I should see 6v at the input. |
Aaron Cox |
Aug 13 2006, 08:51 PM
hook it up. (IMG:style_emoticons/default/smile.gif)
Trekkor |
Aug 13 2006, 08:56 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Toast |
Aug 13 2006, 10:46 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
Allan |
Aug 16 2006, 03:42 PM
Finally!
Everything seems pretty well dialed in and the car goes like stink. For you guys running carbs with the solex cam, is it normal for the motor to have a somewhat lumpy idle up to about 2k? Once past the 2.5k mark it tries to throw me out of the rear window... (IMG:style_emoticons/default/burnout.gif) |
Aaron Cox |
Aug 16 2006, 03:43 PM
:toldyouyouwouldloveit:
Lo-Fi Version | Time is now: 8th June 2024 - 09:51 AM |
