can you change a 1.7 into a 2.0? |
HeloMech |
Aug 15 2006, 09:56 PM
Go Ahead, Get Pistoph! Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California |
I have a stock 1.7 and I'm going to pull it out for new pistons, etc. What can I do to make this a 2.0? Do I need a whole new case, crank and everything? What's the best route to getting a 2.0 upgrade?
Thanks |
G e o r g e |
Aug 15 2006, 10:00 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
if you want a true 2.0 then you will need to change the crank if you go to a 1911 you need to change is p&c plus head work( this is needed either way ) (IMG:style_emoticons/default/beerchug.gif)
914werke |
Aug 15 2006, 10:08 PM
"I got blisters on me fingers" Group: Members Posts: 10,140 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Go 1911 (IMG:style_emoticons/default/aktion035.gif)
Definitly worth the few $ necessary. 1.8 or 2.0 heads will be ncessary though it is possible to mod the 1.7 heads to work... or Ill sell you a set of 1.8 heads I have cheap (IMG:style_emoticons/default/biggrin.gif) |
So.Cal.914 |
Aug 15 2006, 11:59 PM
I did it to my 1.7, picked up a crank and had it counterbalanced, set of rods
those too were balanced and a set of KS 94's for a 2.0. Heads will need to be flycut for the cyl's to slip into them, I also did porting and valves, it helps. Your "everything else" will work just fine. It's like night and day have fun. |
lotus_65 |
Aug 16 2006, 05:41 AM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
are you going to stick with the fi, or go carbs?
the cam can have a big impact on power, especially if you switch to carbs. either way, opening the case to inspect and upgrade might be worth something. from what i understand, the 1.7 case is a great starting point for engine building. |
ptravnic |
Aug 16 2006, 05:53 AM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
I did what you are asking about. 1.7L --> 2056cc. Stock 2.0L were actually 1971L... I've stuck w/FI although the MPS will need some fine tuning. Before that tweak, other things will be required
-Need stock 2.0L crank & rods -Need new cam (Raby 9550 or Webcam 73) -Need matching lifters -1.8L or 2.0L (NOT BUS) heads. 2.0L heads are MUCH more expensive than 1.8L -Pistons & Cylinders - there's some options here. Why not use 96mm as opposed to stock (dish no less) 94mm? At a minimum use 94mm "euro spec" aka flat top pistons. Varying schools of thought on cylinders. Hone out your 1.7L, 1.8L, etc... Or go completely apeshit and buy Nikkies ($$$). -Gasket set Then there's balancing, clutch, etc. Of course none of this accounts for the "while it's out" disease... Maybe rebuild the tranny too? Maybe new engine bay rubber? Oh, the humanity... The men in white coats are coming into the room again, they've got that jacket w/all the buckles.......NONONONONONONO! |
Jake Raby |
Aug 16 2006, 06:51 AM
I offer a kit to make a 1.7 or 1.8 into a 2.0 for the major internals.... The 2.0 core parts are the most expensive part of the process..
Lo-Fi Version | Time is now: 8th June 2024 - 02:11 PM |
